Pretty sure that every nissan, ever, has used the same radiator cap, and it is very common industry wide. The one on my stagea is off a mazda 3.
Found some cancer in the topical location for 31’s, do some emergency surgery over the next few days and see if it’s a show stopper for this silo.
Thank you for posting a follow up with the fix it really helps others when they are having the same problems
This happened to me, Its an easy fix. The control switch you use to turn on the lights have metal 'tags' inside that switch between the options on your knob. those tags wear out and can easily short. I bit the bullet and bought another light switch. unfortunately i had to buy the whole surround to get that switch hahaha
If you 100% know there is air coming out of the cam cover or crankcase then yeah it could be a hairline crack anywhere on the top end. if you cant afford to replace the whole thing you could add smoke to your intake to trace the leak then just replace the part that's leaking. you never know if could just be a valve? just make sure you clean it up properly afterwards
