Hey guys,
i think it must have been a thread that got lost with the down time... but someone wanted me to let them know how it went when i got my BOV put on...
I response to that... SWEEET.... i have it tuned so it flutters down low and makes the big WAAAACHHHSHSHSHHHHH up high....
havn't had any problems with stalling or backfiring or anything so it's all good...
Also, how much would you usually pay to have a BOV like this installed on a R32 GTS-t? I reckon i could have done it myself but the ppl who i got the car off said i have to have it done there to keep warranty... damn b4st4rds charged me $200 for it too... bit pricy i reckon... what about you guys?....
https://www.sau.com.au/forums/topic/28459-gfb-hybrid-bov/
Yeah, that's what i originally though, but because you cant face the trumpet up... they had to extend the plumback tubin (cutting the metal pipeline) so that the tubing could be bent the right way to go onto the bov...
About 1/2 an hours work i reckon... damn B4ST4RDS, they know i wanna keep my warranty... so they charged a stupid price...
https://www.sau.com.au/forums/topic/28459-gfb-hybrid-bov/#findComment-589923
Yep, mines blue too... :)
yeah, i got the adapter for $50 as well... got the BOV for $250.... all straight from GFB...
To mount it, youll have to point the adapter towards the drivers side and face the trumpet forward... that's the easiest way so that the hoses will bend efficiently....
I thought it'd be better to cut a circle in the bonnet and place fine mesh over it (on the underneath so it looks good from outside)... then face the trumpet up.... maybee that can be a future mod for me... :D
https://www.sau.com.au/forums/topic/28459-gfb-hybrid-bov/#findComment-590114
yeah they are a good thing to have, mine was stalling before i had the plumbback attached, only cost me $100 bucks but i think that was a bit dear when look at what was done!!
glad your happy with it though!
https://www.sau.com.au/forums/topic/28459-gfb-hybrid-bov/#findComment-590746
adapter... with the size of the BOV, won't you have truble fittin it under the bonnet with that adapetr?... Looks like it's designed so the BOV will stand up on it???
Do you hav a mount set up for it or something?....
To tune it, the guy at GFB told me to adjust the nut lookie thing on the top (i think he called it the actuanator or sumfin...) about 1/2 a turn at a time and see how it goes... he said it's ok to flutter under about 3500RPM and about 3-4PSI...
https://www.sau.com.au/forums/topic/28459-gfb-hybrid-bov/#findComment-590758
instantly went into "R32 mode" in my head... lol
Yeah, wouldn't have a clue about any others so the mechanic would be right....
If ya have any troubles with adjustment, just ring the guys at GFB... they're really good... they'll tell ya exactly what to do... I wrote down what the guy told me but can't find the bit of paper... lol...
https://www.sau.com.au/forums/topic/28459-gfb-hybrid-bov/#findComment-590859
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
