RB26DETT Block and girdle, dipped, bored, honed and decked. Has all welch plugs removed, has been bored to 86.5mm. Has had deck faced to tidy it up a bit.Mains girdle fitted to check clearences measurements etc. Work on block cost $450, selling for $400 plus freight
Brand new Nissan RB26DETT crank, long snout version, still in unopened box $800
STD Coil packsx12, 6 of them were out of a 105000km car, removed due to upgrade, 6 were out of a 120000km car which i bought for spares and wrecking, these ran well with no signs of breaking down. $40 plus freight
Coil pack wiring loom $20 plus freight
Master cylinder BM50, 1" R32 GTR $50 plus freight
R32 GTR Starter motor $30 plus freight
White Passenger side door, complete with door trim $100
Heaps of other bits and pieces, put a request in as nothing is too small.
Still wrecking White R32 GTR, has got compliance plates etc
Thanks,
https://www.sau.com.au/forums/topic/284610-r32-gtr-wrecking-and-parts/
Have also got Rear cradle, almost complete, needs the rear steering arms, comes with brakes/diff and all suspension arms etc $800 plus freight
4xGMAX wheels, great brake clearance, bit dirty and a few stone chips. 17x8 NO tires, would make great club day wheels R32 GTR Stud Pattern and offset $200
great prices mate! i wish i had spare cash...
What are you after mate? I am open to layby if you want something bad enough. I did it for Ali-Turko with a pair of turbos
Michael
0438911374
Got any brakes for sale??
Have got a pair of alcons to suit R32 GTR,
If you wanted too we could arrange something like a layby system or whatever if you wish
Call me on 0438911374
For sale, Alcon 4 piston and 320mm rotor brake setup for R32 GTR,
Thick long endurance pads with plenty of pad left, high heat pads.
Rotors, 2 peice slotted rotors, 320mm diameter, 36mm thick curved ventilated rotors. they will clear 16inch Enkeis, not sure bout std 32gtr wheels. Could probably modify to fit bigger rotors on
Come complete with rotors, calipers, pads, braided brake lines and the spacers, just one small mod and they are ready to go
All setup to suit R32 GTR, one small modification needed to hub assembly to put on.
Awesome brake upgrade, would suit targa/ track days etc, worked very well on my car
Call me if you wish to discuss or see photos. 0438911374
Oh yeah they can be yours for 2200
Michael
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
