RB26DETT Block and girdle, dipped, bored, honed and decked. Has all welch plugs removed, has been bored to 86.5mm. Has had deck faced to tidy it up a bit.Mains girdle fitted to check clearences measurements etc. Work on block cost $450, selling for $400 plus freight
Brand new Nissan RB26DETT crank, long snout version, still in unopened box $800
STD Coil packsx12, 6 of them were out of a 105000km car, removed due to upgrade, 6 were out of a 120000km car which i bought for spares and wrecking, these ran well with no signs of breaking down. $40 plus freight
Coil pack wiring loom $20 plus freight
Master cylinder BM50, 1" R32 GTR $50 plus freight
R32 GTR Starter motor $30 plus freight
White Passenger side door, complete with door trim $100
Heaps of other bits and pieces, put a request in as nothing is too small.
Still wrecking White R32 GTR, has got compliance plates etc
Thanks,
https://www.sau.com.au/forums/topic/284610-r32-gtr-wrecking-and-parts/
Have also got Rear cradle, almost complete, needs the rear steering arms, comes with brakes/diff and all suspension arms etc $800 plus freight
4xGMAX wheels, great brake clearance, bit dirty and a few stone chips. 17x8 NO tires, would make great club day wheels R32 GTR Stud Pattern and offset $200
great prices mate! i wish i had spare cash...
What are you after mate? I am open to layby if you want something bad enough. I did it for Ali-Turko with a pair of turbos
Michael
0438911374
Got any brakes for sale??
Have got a pair of alcons to suit R32 GTR,
If you wanted too we could arrange something like a layby system or whatever if you wish
Call me on 0438911374
For sale, Alcon 4 piston and 320mm rotor brake setup for R32 GTR,
Thick long endurance pads with plenty of pad left, high heat pads.
Rotors, 2 peice slotted rotors, 320mm diameter, 36mm thick curved ventilated rotors. they will clear 16inch Enkeis, not sure bout std 32gtr wheels. Could probably modify to fit bigger rotors on
Come complete with rotors, calipers, pads, braided brake lines and the spacers, just one small mod and they are ready to go
All setup to suit R32 GTR, one small modification needed to hub assembly to put on.
Awesome brake upgrade, would suit targa/ track days etc, worked very well on my car
Call me if you wish to discuss or see photos. 0438911374
Oh yeah they can be yours for 2200
Michael
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
