nismogirl,
maybe you have the new PFC version?? Does your alsd light even come on when you put it on ignition? if it doesnt, then it is likely that your light has been taken out, which is why u dont ever see the light come on?
if all is still ok, then you are just lucky!
Moanie,
no probs ;)
  • Replies 158
ah yes i know! everyone i know loves the car, the problem is i need to start up my business, as i dont work for anyone anymore (i like it that way too!), so i will be needing the funds to get things started. i will get another skyline again though, i just need the funds for other things right now.
..also...i think ive seen you and your car in a cruise or two in the past ;)
you don't neeeddd to sell it though!!! you can just leave it in the garage! start the engine once in awhile.. make sure shes all cool! and get a loan to get things started!!! selling the 'line is toooo much of a sacrifice!!!! ;)
hahha... really? which cruise? and which car was yours!? lol!!! sorry if we've met and i don't remember it! :)
  • 2 months later...
Hi y'all - I B A Noob to this forum so be gentle!
Has anyone driven the standard LSD and the Active LSD? Is it worth hunting around for a car with the Active Diff ? (Currently scouring Melbourne for the "right" R33 GTS-T).
It sounds VERY much like a Power-FC problem to me. Do you have the manual for it? perhaps you could phone a couple of jap-tuning specialists and ask the hard questions. Computers in cars tend to get narky when they're not fed the signal they're expecting, and it doesn't take much to upset the apple cart ! ! :looney:
I think it was pretty much summed up on page 1
"The active LSD on some GTSs uses a signal from the ECU like the GTRs do and i don't think PFCs have this function but as of now the Wolf plugin dose.
A clever electronics person could modify the TPS signal to send the inverted signal to the ADCU."
if steve is correct and he probably is if wolf now do it , you need to send a modified tps signal to active lsd . the power fc wont feature this , just as it wont send signals required to the auto transmission computer in auto skylines .
i dont know why nismogirls alsd works with the powerfc , but it could be
a. her latest powerfc does support this
b. whoever installed the powerfc has sent the tps signal also
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
    • Had I known the diff between R32 and R33 suspension I would have R33 suspension. That ship has sailed so I'm doing my best to replicate a drop spindle without spending $4k on a Billet one.
    • OEM suspension starts to bind as soon as the car gets away from stock height. I locked in the caster and camber before cutting off the kingpin. I then let the upright down in a natural (unbound) state before re-attaching it. Now it moves freely in bump and droop relative to the new ride height. My plan is to add GKTech arms before the car is finished so I can dial camber and caster further. It will be fine. This isn't rocket science. Caster looks good, camber is good, upper arm doesn't cause crazy gain and it is now closer to the stock angle and bump steer checks out. Send it.
    • Pay careful attention to the kinematics of that upper arm. The bloody things don't work properly even on a normal stock height R32. Nissan really screwed the pooch on that one. The fixes have included changing the hole locations on the bracket to change the angle of the inner pivot (which was fairly successful but usually makes it impossible to install or remove the arm without unbolting the bracket from the tower, which sucks) and various swivelling upper arm designs. ALL the swivelling upper arm designs that look like a capital I (with serifs) suck. All of them. Some of them are in fact terribly unsafe. Even the best one of them (the old UAS design) shat itself in short order on my car. The only upper arm that works as advertised and is pretty safe is the GKTech one. But it is high maintenance on a street car. I'm guessing that a 600HP car as (stupidly, IMO) low as you are going is not going to be a regular driver. So the maintenance issues on suspension parts are probably not going to be a problem. But you really must make sure that however your fairly drastically modded suspension ends up, that the upper arms swing through an arc that wants to keep the inner and outer bolts parallel. If the outer end travels through an arc that makes that end's bolt want to skew away from parallel with the inner bolt, you will build up enormous binding and compressing forces in the bushes, chew them out and hate life. The suspension compliance can actually be dominated by the bush binding, not the spring rate! It may be the case that even something like the GKTech arm won't work if your suspension kinematics become too weird, courtesy of all the cut and shut going on. Although you at least say there's no binding now, so maybe you're OK. Seeing as you're in the build phase, you could consider using R33/4 type upper arms (either that actual arm, OEM or aftermarket) or any similar wishbone designed to suit your available space, so alleviate the silliness of the R32 design. Then you can locate your inner pivots to provide the correct kinematics (camber gain on compression, etc).
