Hey guys, drove around today with no problems, but on my way back home, sounded initially like i had a flat tire, then realized was the engine.
Car sounds like a wrx (which isn't normal lol), if i'm rolling along, the engine will stutter, especially when accelerating. When travelling along, the engine will slow down then burst forward for a sec, then back down etc.
Got a booking fr Trojan on Thursday, but its a 40-50 min drive from my place, and seemed to be getting worse on the 10 min drive to my place.
Any idea what it could be? Just wondering if I should drive it on Thursday, or get it looked at by someplace close perhaps tomorrow or tuesday first.
The only weird thing I can think that happened, was yesterday, my nan was watering the garden and somehow lost the hose, went under the car and drenched the engine bay from underneath. I noticed the pod filter was a bit wet but left it overnight/day to dry and like i said, it ran fine......
If you haven't guessed, i know next to nothing about this stuff...
https://www.sau.com.au/forums/topic/284648-engine-stuttering/
If your pod filter's wet then it's very likely that you've gotten your airflow meter wet. Could be that. It could also be the electrical contact for the crank angle sensor has gotten wet, which isn't far from the air filter.
Could be your coilpacks starting to bomb out by coincidence, but that only really happens when you rev/boost it hard and flat footed (initially).
Does it matter if the engine's warm or not?
Thanks mate,
Nah dosn't matter if the engine is warm, drove home which was like 15-20 min drive, did it the whole way
Should mention that my engine is stock. just got the pod and zorst.
Edited by 33Sedan
my silvia (RB20) sounded like a wrx when running on 5 cylinders on idle but as soon as you started driving itd run on 6 cyls. possibly coils. just get some splitfires and see what happens.
could it be the spark plugs not firing right
I'm not sure, that was my initial thoughts. Hmmmm...... Might drive it to my local place, see whats wrong, if they gotta replace stuff i would prefer trojan to do it - except not really wanting to drive it all the way there lol.
.......or depending if you can get it to do it at idle
easy way to test the coils is by unplugging them one at a time. whichever one doesn't make a difference.... will have some issue with it.
man i had the exactly same issues here. my RB25de Neo have some trouble with missfiring. because it sounds like a WRX. probably chilling winter in canberra?
if u start the car in the morning (or when the engine is cold) it sounds ok for 5 minutes (because the car automatically retard the firing). after 5 mins the timing gets advanced to normal state, thats when the engine sounds like WRX.
i'm opening my intake plenum now and will open the cover tomorrow to check and replace the spark plugs / coils / looms. or even injectors.
http://www.skylinesaustralia.com/forums/Ne...49#entry4774549
if u'll bring it to local workshop, will u share the answers with me?
cheers.
One thing he's forgotten to tell you though don't unplug them/plug them in while the car's running... right James? :D
OMG TOOK THE SPARK PLUGS OUT WHILE IT WAS RUNNING AND THE ENGINE WON"T START NOW>.......
just kidding ;-)
Thanks guys, getting it towed to trojan tomorrow. gtrkat, your price was spot on! Thanks!
Trojan thinks it could be the spark plugs or coil packs ;-)
Will see on wed/thurs. Hopefully won't break my bank account...fingers crossed!
Good luck mate, i had an issue with mine not long ago where it would just stop accelerating all together, then it'd kick back in and cut back out, all within the space of a few seconds. Took it to Ed at AutoTech and it turned out to be the solder on the wires in the AFM had come loose and were barely making contact causing the PowerFC to think there was no airflow coming in and cutting the power. To make matters worse had a grounding issue at the same time and one problem masked the other.
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
