I have a r33 GTST with i think superlight weight shockproof oil. (blue in colour) The car now makes some decent power and after some hard driving, quite alot of gearbox oil has come out the breather, so now l have decided to change the gearbox oil as well as the diff oil. I just bought some heavy shockproof oil thinking that this was the oil in the gearbox but, opening the bottle l noticed that it is red in colour meaning the oil that is in my box is either light weight or super lightweight. Has anyone used super heavy shockproof in there gearbox and what is the shift like. Thanks.
https://www.sau.com.au/forums/topic/284677-redline-heavy-shockproof-oil/
i wouldn't run either oil in your gearbox if its a servicable unit. Castrol Syntrax is what you should be using. Id only put Redline Lightweight shockproof in a worn gearbox thats difficult to shift as a temporary measure until box is rebuilt.
Have used Lightweight Shockproof in many 33's without issues of any kind. 100% of the time the customer reports smoother shifting.
Heavy shockproof will cause a notchy shifting feel
Notchy only when cold I have found... once warm it is smoooth as silk
I thought lightweight shockproof was only recommended as a stop gap to keep worn boxes going a bit longer. Wouldnt you have been better of with MT90? Since you've got a shiny new gearset it might be worth ringing up Redline and speaking to them directly to get the info straight from the source...
This seems to be a continual source of confusion, I ran MT90, my box didn't like it, Redline Lightweight shockproof is smoother.
If you read carefully, the American redline website does NOT recommend due to some regulations.
The Australian website DOES recommend it, and I've seen it written in there books.
If you end up buying some, its expensive, try performancelub.com , I don't think heavy shockproof is for any skyline....
My gearbox is in perfect nick, I put lightweight shockproof in it just because I've got some crunching at the track (and only at the track) with the previous fluid (most likely genuine nissan gearbox fluid)
It's a 2000 KM old OSG 5 speed. Fresh as a daisy.
Interesting - was this a newly rebuilt box? IIRC there was post ages ago from someone who had problems with a rebuilt box and light shock.
Umm, you says its in perfect nick but it crunches? Call me stupid but wouldn't that imply its clearly NOT in perfect nick? Or are brand new boxes known for crunching gears?
So you have a 5 gear set in the standard case? Who supplied the synchros and are they genuine items?
Yes thats right. OSG 1,2,3 with heavy duty input shaft and I chose to use a stock Nissan 5th gear as it is taller then the OSG item. Synchro's are all genuine, most of which came out of the box I smashed to bits. That box had 11,000 KMS on it.
Some people are totally for the redline stuff, yet others wont go near it. On a side note when the new Nissan 5 speed box went in Just Jap wouldnt warranty the box unless Redline lightweight went into it.
Note I said only at the track, all Nissan 5 speeds have the common redline 3rd to 4th crunch gear change (if shifted quickly), i believe it's a design fault with the 3rd and 4th gear.
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
