hey guys, i have bit of a problem with my r32 gtst, (RB20DET).. When i start my car cold.. it runs very well...idles at @ 1000RPM... then after 6 mins... idles drops to about 750- 800RPM.. and run rough.... then @ 11mins, the engine hunts between 100 - 1000RPM.. then stalls ( at running temp.. about 60 degrees)... i try start the engine agian then idles up to 1000RPM then stall straight away.... my dads a mechanic and we have tried everything... replaced all the vaccum lines.. checked all the intake piping...
possible ECU problem??? or something electronic??
i would love some help guys... cheers... im running these things in my car too
## Microtech 3 Bar Map Sensor
##Microtech LTX-12 Engine Management System
##Microtech 4-Line Handset
##Greddy Profec B spec II Boost controller
cheers. Jamie
https://www.sau.com.au/forums/topic/284686-car-starts-when-cold-dies-when-hot/
hey I was going to say the choice of computer was the issue too :thumbsup:
a common problem when hot is the ignitor on the back of the motor for the coils, are you still running it? If so change it for a known working one and see how you go.
Is the microguess install new? you have to be careful with injector and coil settings, you can burn things out pretty easily by getting them wrong
hey,
Moodles.. Thx for the reply... i shall try get my hands on a stock ECU .. but tht might be hard..
Duncan.. Thx for the reply... i am really new to cars and my old man is new to the jap car scene aswell.. we had a read thru the micro tech programming book.. and we think when the car is hot its not getting enough fuel wen the choke is turned off... or something like tht.... ummm also we tried programming it with the hand piece and .. "murphy's LAW" the hand piece doesnt work... or it will not do what the book says =/..... thx for the ideas...
also i dont know is the microquess install is new.. and the coil packs in my car arent stock they were changed out to "Bosch HEC715 Ignition Coils "
cheers guys, Jamie
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
