Hey guys,
I am just posting to get some opinions on this from owners of stageas or people in the know.
http://www.skylinesaustralia.com/forums/La...84#entry4783284
I get my P's next month and for I am looking at getting something similar to this or if it isn't sold, possibly this one.
Would this be a good choice as a first car if it is N/A? If it isn't N/A would it be worth buying and taking the turbo out? How are they on fuel? How much would it cost to get the turbo taken out and then the work done to make it run properly without it?
Anyway, any opinions would be greatly appreciated.
Thanks alot. :devil:
https://www.sau.com.au/forums/topic/284690-stagea-on-vic-ps-opinions-wanted/
you're lucky you didn't post this on another forum or you'd be flamed something chronic :devil:
the question of de-charging a factory turbo motor gets asked alot, and in short, the response is don't bother. the compression ratios aren't set up to run naturally aspirated and would be about as powerful as an 1800kg excel
as for fuel consumption, it depends how heavy your right foot is, they generally aren't fantastic though
You cannot take the turbocharger out.
Engine number / chassis number will bring up flags that it is a turbocharged model REGARDLESS if you've taken it off. They're registered / stamped as a turbo model for a reason.
There are no loop holes or ways around it so you will have to buy a naturally aspirated model.
That Stagea will not be suitable because
1. It is modified
2. it has a turbo
3. It has better than 125kw per tonne (just)
I think the cops will go by the plate anyway (RB25DET) and it won't help you to remove the turbo (but you could check).
If you did remove the turbo it wouldn't even go as well as a n/a neo Stagea and would probably use even more gas than they do already!
PS if you can find one the late S1 n/a Stagea has the neo engine ( I had one) and they are almost as quick as a stock S1 turbo. They are about $3000 in NZ but I think they are quite rare in Aus.
Go with QWK32's suggestion - get a cheap to buy, run and insure car and save up for a better car when you are qualified.
not my suggestion, it was Danny's lol. but still it would be the best option for you Nickz0r!
my suggestion is
get a cheap car to as your first car as you willl most likely crash or damage it
learn how to drive
get off your P's and then get a turbo charged car
in the end its your choice, but many here speak from experience.
i wanted a r32 gtr when i got my p's, but being new to the driving world and never driven a turbo, just a RWD NA, i would of treated it the same and be wrapped around a tree.
but the chance of cops pulling you up in a 'stock looking' stagea is rare, i've driven through blitz nights and booze bus's, even been stalked by cops, i guess they just dont bother.
then again there always has to be some one unlucky out there. . . ..
my suggestion is
learn how to drive
x2.
You're fresh off you're L's and probably pissing straight testosterone. Wait a few years before buying a Turbo car.
x3 on the 'try a different approach' theory.
But NA Stagea = PM35 350RX FTW
:thumbsup:
But seriously, I think you'll be stuck with something much less gracious regarless of your good intentions. If you're after a wagon, and Nissan, then a nice S3 R31 would be a reasonable thing (and less than $5k). I'm not trying to force you into the stereotype of P-plate R31 owners, but there you go!
FWIW, I bought my 240Z when I was 19 (first car). By the time I was 21, it was running a custom EFI L24 Turbo and produced a little over 200% factory kW at the rear wheels... I haven't really ever bent it (curbed it once, trashing a control arm & slightly creasing a guard), but all my mates did something, and it wasn't always their fault. You're just a magnet for shit-happening at that age!
well....
n/a stagea...
quite rare
i guess it'll work out well
get a n/a stagea get off your P's
RB26DETT :)
and your set :)
Find me one. :)
:thumbsup:
It's not that I'm after a wagon so much. It's just that the stagea I posted really grabbed my attention and I really liked it.
But I've been looking at R31's, and I've come across only a couple that look in good condition that don't need alot of work. :\
Hmmm, as far as I knew, N/A Stageas were ineligible for import approval anyway (until the atmo M35's finally gain complaince), so finding one would be extremely difficult - it'd probably be a private individual import. And having a C34 with an atmo RB25 trying to push around ~1600kg's of car is not my idea of a worthwhile buy, even if it was just to cruise around. They're heavy enough on fuel as it is, and having to push it to keep it even mildly moving along is not going to help lower its fuel use.
If you have been looking at R31s, you DO have to remember to take into account that they are between 20-25 years old now...
Yeah, I think I might just have to give up on the idea.
And like I said in the post above yours, it's hard to find ones without problems and don't need a lot of work and maintenance.
Back to the drawing board. :thumbsup:
The n/a stag was listed on carsales... I remember it was a dark green one: if you look for it, you'll probably find it.
Also, if you're after something a little different, and fun to drive, there was an atmo Mitsubishi Legnum for sale on carsales when I was looking a few weeks ago: pretty sure it was manual too. A stocko Legnum will obliterate a stocko stag in the handling department (I had a bog stock twin turbo Leggy, and it was one of the best handling cars I have ever driven), so it may be an option if it's still available?? Worth a look, at any rate. I believe this one was a private import as well, so you're not likely to see another one any time soon...
Just a suggestion.
Just a suggestion.
There was a dark green NA one in QLD not that long ago for about $5k....look on there.
http://www.carsales.com.au/all-cars/privat...5&silo=1011
It must be gone. These are the only 3 green stageas on carsales, all of which are turbo.
I think I'll just be looking for something else.
Thanks guys.
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
