Hi, i have a r33 1993 november build gtst series 1. Its black with gold 3 piece rims geewlat brand rims. Tyres are 235x40 @ 95% tread on the front & 265x35 on rear at 85%. It has a front mount intercooler (monta imports), turbo smart t-boost set at 9 psi and HKS pod. Also has 1,3,5 min turbo timer, controller is built into dash. It has a momo steering wheel and momo chrome gear knob. It has a 3.5 inch turbo back exhaust with a 5 inch tip with silencer in it. It is a loud car but i have a exhaust that will fit to get you through the EPA, this exhaust will also come with the car. A big wing is on the back that makes it look like a shopping trolley, so the missus says.
Body condition is in great, no dints but does have a scratch on the back left hand side of the rear bar and also a cracked front bar that i have resprayed where the cracks are to be not so noticable, also a bit of black tape to not crack any further. Will need to replace front bar or get it repaired for it to look better.
Other things wrong with it are the drivers door electric window motor is blown or/and the relay has shit itself. Im sure its both as i crossed the wires a bit back to get the window to go up and down as the reley was playing up and they touched, the window motor doesnt work anymore although it is all the way up.
It also has a blown head gasket.
It has just had a new timing belt and new air con belt put on. Also had the air con pulley replaced. Also a re-cored radiator
It has a dvd, tv, gps, cd palyer in 1 in it but a cd is stuck in the player(cant be bothered pulling the thing out to get the cd out, i hope you like 2pac). It has 6X9 200w pioneers in the parcel shelf and great speakers in the front, cant remember which brand, but they were green and are brand new speakers front and rear, all new wiring! Interior is in great condition and is very clean.
This car was imported and i bought it 2 weeks after it landed and was complied. Ive owned it for approx 3 years. It has been great to me and has been a quick and fun car to drive as this was my dream car but due to the problems with it and my wife is due with our first baby in 3 weeks i need to sell it. This is a regretful sale, trust me!!
The sale price is $8000 negotiable.
Does not come with rwc or rego
Please email me at [email protected] or phone 0418174568 after 5pm any night.
https://www.sau.com.au/forums/topic/284724-1993-r33-gtst-series-1/
Hahaha "hope you like 2pac" Pure gold.
he's right about the price though. I've been trying to sell mine and it's only got a blown turbo and i've had only 3 people interested in buying. About 30 people wanting to trade though.
Especially with no rego.
Good luck with the sale though man.
  • 1 month later...
  • 1 month later...
    • Yucky. Things haven't gotten any better though. Now you have Emerson and Honeywell pushing these massive DCS/Scada things with proprietary hardware. They're not a PLC, they're not a computer, they're a...distibuted PLCish/DCSish monster of thing, that only they can program because they make the barriers to entry for anyone else so fricking high. And their developers are all located in the third/developing world (and India, in case anyone does not include that place in that category) and there are terrible failings of the ESl variety, of the care and common sense variety, and f**king forget about Functional Safety. Not a one of them has any idea what it means to comply with an IEC 615xx series standard.
    • All of the ECU grounds are to the chassis, the IGN grounds are to the cylinder head and i believe all the OEM body harness are left in original locations, im trying to work out if i can tell if the sensor voltage itself is losing any power to it from the very low ECU voltage. But yeah a manual pressure gauge will help in picking which path to actually chase. Also please dont bully my wiring plan i never designed it to be universally understood hopefully it still can make sense to you, im a wiring virgin.  1 thing i have just noticed the pressure sensor in question relays both pressure and temperature, the temperature reading holds nice and steady despite the low ecu voltage but the pressure reading is the one that jumps around alot so maybe it is really a pressure issue? wiring plan.xlsx
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
