hey guys,
I have abit of an issue with my car (r34 gtr) at the moment and just wondering if you guys might be able to lend a hand and give me some ideas on what the issue could be. Installed a pair of HKS2530's that I purchased from a forumer not long ago. Put the car on the dyno for a tune last weekend and the car wouldnt boost over 0.6Bar. We took off the waste gate vacuum line to test the boost but still, it would not go over 0.6Bar.
I did a quick search on here and seems the usual troubleshoots are to check the lines and cooler piping. I went and got a 'smoke test' done on the car to see if there was a leak and where it could be coming from. There was no leak.
Im abit stumped as to what it could be...could cam timing cause this boost issue?
Cheers
https://www.sau.com.au/forums/topic/284746-car-not-boosting-past-06barhelp/
Hey man, i had a similar issue with mine; on the dyno getting tuned with a newly installed evc it wouldnt boost past 0.5-0.6 bar. At first they checked vacumn lines n found nothing so we thought it was an issue with actuators or the boost controller but after careful check it turned out to be a vacumn line, not sure which one but it gave rob from creatd ms a headache for a couple of hours.
I remember vaguely somewhere under the plenum???
hope you sort it out mate, good luck!
thanks for the reply man. I will probably be changing out the vacuum lines just for good measure. Hopefully that fixes things. Although, it should have boosted as we took out the wastegate vacuum line? did your mechanic try that when you had your problem?
Hey man, npz i jst hope you get it sorted so you can enjoy your car.
we didnt try anything with the gates as that could be quite dangerous, found the problem beofre anything like that had to be attempted. Could it be the turbos? are they new?
maybe check to see if the installation was done right, gaskets etc or maybe its the intake rubber pipes sucking shut when it reaches 0.5bar
i dunno just throwing ideas around now cos i have no idea
goodluck bro, keep us updated
I had similar problem with hks gt-ss turbos not boosting up, no matter how much I tried winding into them. Same thing with disconnecting actuator lines. Turned out to be collapsed cat converter - the more the car revved, the more backpressure was created so no extra boost. Drop the exhaust at y pipe and see what happens before you go any further. It's turned me off running cats ever again after that.
I have actually de-catted my cat (looks like a compliance cat), to prevent that from happening.
definately frustrating as I cant wait to wake up these turbos.
update:
still havnt figured out what wrong with it yet.
Pulled off the cam gear cover and found that the car came with Tomei Adjustable cam gears....which brings me to my question. Can cam timing affect boost? As i suspect the timing is off.
Cheers
    • Pre-empting heat management  1. The Kraken manifold will be ceramic coated 2. Just purchased some peel and stick heat shielding stuff from car builders, I'll cover some of the firewall behind the dump and a little on the cam cover, this will be done prior to installation as I have ample room to get where I need to now before that realestate has more bits in the way, I'm also planning to modify the OEM heat shield to go back on, but that won't happen until after installation so I know where to hack it up, I'll also cover it with some some peel and stick to neaten it up after the hacking 3. As the dump is stainless with a flex joint coating isn't really a option, and wrapping isn't recommended for a stainless dump, so once it is installed I'll grab some shielding from car builders to cover the dump, as it has some stand off, it "shouldn't" cause any issues and it "should" just keep the radiant heat away from " melty engine bay stuff" Not for heat management, but I've grabbed some more black crinkle coat to paint all the shiny intake pipes, I'll pick the pipe work up prior to installation and use the paint booth and big oven at work to cure them, I'll then wrap them with some bubble wrap so they stay nice during installation
    • We're back on, gang - Our yearly pilgrimage south to our favourite cafe for an awesome brekkie! Yes, that's right... we're heading down to Austi Beach Cafe for a breakfast run through the Royal National Park! Before you drool over your phones/keyboards, here are the details: Date: Sunday 23rd February Meet Location: Loftus Oval Carpark, Royal National Park, Sutherland Meet Time: Meet at 7:00am for a 7:30am departure Destination: Austi Beach Cafe, 104 Lawrence Hargrave Drive, Austinmer Map: http://tinyurl.com/saunsw-austicruise  RSVP: If you are planning to sit and have breakfast with us, please let us know, either by posting in the event, or by messaging us direct so we can confirm numbers with the venue. Itinerary: We will meet at Loftus Oval Carpark which has plenty of room and is low car friendly. This is a quick turn into the Royal National Park and some nice roads and scenery. After Stanwell Tops we will turn off and head onto the awesome Sea Cliff Bridge. Following this it is a short trip to Austi Beach Cafe. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • YO- have been searching and searching for an a31 chassis plug pinout, or someone who knows which wire is for tach.  ceffy was flooded past dash during a hurricane.  having an electrical gremlin appear. tach is wonky reading consistent with a short, and on occasion the right side of my speedo lighting will flicker just for a second then go back to normal.  if no pinout available does anyone know if the tach harness opens or branches anywhere behind the dash? im suspecting a possible root behind the radio as there are more shorts in that area on the accessory loop.
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
