The RED car with thr R31 GTS front bar is built by Randy at Nissco in Bayswater VIC
It has a 2.2 liter, meaning bored out with bigger pistons, its NOT a 2.4,
Call randy, say your interested in brining it back to VIC and he will sort you out, and let you know the story how its one of the only cars they had to chain down on the dyno cos as it came on boost so hard it wou;d try and jump off!
I say go for it, I wanted it a few times myself.... it is built well and obviously can take it.
  • Replies 80
Thanks man ill do that
KN R30
So Can a South African car be registered here in vic? i guess thats really all i care about right now can i get a road worthy and register this car in vic? also what paper work does the car need to have with it to make this happen?
im well aware its to dear i dont need to be told this again lol
Registration should not be a problem as it originated in Vic, but I would assume, if proof of registration interstate was provided, it would nearly be just a matter of going through the motions to make it comply with the particular states parameters.
Just try to deal with the guy & if you can cut a satisfactory deal, go for it, as at the end of the day, there is only one person that has to be happy and that is you!
Parts really aren't so hard to find, just a tad more expensive these days due to age & importing from Japan.
I can't understand why groups of guys/gals don't get together and form buying groups to get the bits from Japan they want and therefore combine the postage to save a little money.
Cheers, D
:) With the current seup it's running now? VG30 turbo and all?
My mates 2.1 FJ when it was running a VG turbo didnt come on boost hard at all, was smooth as and already building boost by 1800rpm completely run out of puff by 6000rpm though
:D With the current seup it's running now? VG30 turbo and all?
im not sure, it was 4 or so years ago...
but it seemed mental to them cos they built a heap of L18 powered 1600's and the occasional Z18et... now they do SR20det on a nearly monthly basis
i took a ride in an evo they bult for rally events, bloody hell i nearly shit myself it accelerated so hard, and the brakes were that good i almost got winded!!! the sound of antilag blap blapblap BRROOOOOOOSHHHHH and 4 seconds later your at 100km/h and climbing
i luv industrial estates!!!! :)
Well i brought it !
ill just say i paid less than 5 for it so im happy ! should be a fun drive back from SA
How long will that trip take me?
Congrats Marc... I hope it turns out to be a good purchase.
Adelaide to Melb is 8 hrs I think.
JH
It was definitely an L-block (the FJ's all had LH exhaust outlets), The grille is also from an S2 GT/TI, so KN-R30 makes sense. I'd be pretty disappointed with 150rwkw from a 2.2L w/VG30 turbine & intercooler though...
Hopefully it proves to be 'just right' for what you're after, IMHO the price is 'ok', but I'd be expecting to find some skeletons in the cupboard!
I would have thought 150rwkw @ 8psi was pretty good? i see yours has a list longer than my you no what and its only got 140rwkw? im not sure about these things
Thanks input Ben
I'll be the first to admit that dyno numbers don't tell the full story and we haven't seen any graphs for your new car. But with 2.2L and decent management I'd be hoping for nearly 150 at standard boost. Yes my car 'only' has 140 (it was 95 when I took delivery of it), but it's internally standard, and running about 10psi through the standard turbo.
Things we expect from you:
Lots of photos
A report on the car's condition
registration into the 'registry' thread
:3some:
They don't come up for sale that often, so this kind of thing is a special occasion!
Good for you Marc. FJ22 is my dream engine... Are we going to see any power upgrades in the near future?
Also did you find any decent projects about? I'm sort of in the market for one.
Only cosmetic stuff to begin with new wheels, front, (iron mask) side steps, and two tone paint etc it will look great you will see lol
Lots of photos
:D
I spoke to The guy that built it he said its very restricted currently cause of building it to pass road worthys he says with very litte work (big free flow exhaust, more boost, its a 200rwkw car easy (his words)
  • 4 weeks later...
just a brief update on this car
here it is as it was brought by me
and here it is after iv put wheels and done some paint only started putting on the iron mask front.
now from here im going overseas so there wont be much more till Febuary next year but i have several more bits to go on
-Tein coilovers (ill make it much lower)
-Gtr front brakes
-side skirts
-front skirt
but just wanted to update what do you think so far?
Not bad. did you paint the lower section the correct metallic blue, or black?
I don't know how much lower you'll want it - mine probably rides about the same height as yours and I can only just get a conventional trolley jack under it...
(plus the rear neg will start to get unmanageable)
lol black!
also much lower! i will set it with the front wheels level with the gaurd and the rears will sit under!
like they do with them in japan! there is plenty of room right now under it
Looks 100% better :(
I had to raise my car as it was too low, most of the trouble I had was that the sump sits lower then the cross member, as does the very bottom of the gearbox. So both copped a bit of a beating. Also my radius rod mount bottomed out over speed humps and cops really didnt like it :) There was no thought put into handling like this though as the roll centers were way out of wack and so on. But all of which has been sussed and it is probably a good inch or 2 higher
Edited by DR JOSH
    • Yep, replacing all those hoses is kind of just bog standard if you're ever back there. Only hose on the back of the engine I have yet to replace is a vacuum hose for the wastegate. I'll probably do it eventually but it's in such an annoying spot.
    • I was actually just planning on replacing the fourth gear parts in the gear box that I broke … like the synchro hub or cone. And any other parts I need once I open up the transmission. That a bad idea? The rest of the gears feel tight. these parts shouldn’t be too much … just the labour here won’t be cheap. Just replacing these in HK would be around 2k aud including labour.    how much is a new r33 or r32 transmission?    thanks for the good info as usual
    • I chose a bad time to buy, at the time there was no gtst's for sale in NSW and my options were qld, vic, or sa and not the greatest examples or too far out of my budget. Ended up picking this one from adelaide sight unseen and got a bit stitched up as you could expect but i dont fully regret it, its just a shame people cant be more transparent in this day and age.
    • IMO just buy a whole R33 transmission and swap the whole thing. Use a palm nailer/air hammer with a roll pin punch to drive the shifter rod end roll pins out. The rod end is discontinued so don't break it. Use gasket dressing on the OEM paper gasket instead of RTV. I personally would not pry on the shifter cover tabs, I broke one trying that instead of just smacking the side with a dead blow rubber mallet to shock it loose from the RTV the last mechanic applied. If you can't get the flanges totally clean and free of any residual RTV and/or you might have a gap that is bigger than it should due to flange damage use RTV on that surface instead of the OEM specced anaerobic sealer. Anaerobic sealer is most likely the right sealant for the job, it's just too easy to mess it up with too large a gap or bad surface prep/roughness seemingly. If you do rebuild what you have it's for a whole gearset that can take high torque. Don't bother with OEM at that point.
    • Little hose. Big hose. They're all waiting to kill the engine.
