Reposted due to massive price reduction - wasn't able to edit my last thread.
2003 V35 Skyline Coupe - Twin Turbo
VQ35DE(TT) - 3.5 litre V6 fitted with Power Enterprises Twin Turbo kit:
  • 2 x PE1420 Turbos on custom manifolds
    Front mount intercooler
    High volume sump
    Larger fuel pump and injectors
    Custom piping and air intakes
    HKS Fcon V Pro computer
Other mods include:
  • Nismo - Aftermarket LSD Diff
    Nismo - Exhaust
    Nismo - 280km/h gauge cluster
    Rays CE28N Time Attack edition rims ( 18 x 9.5 +22 )
    Near new slotted rotors
    Project Mu pads
    Pedders lowered springs
This car combines outstanding performance, looks, driveability and comfort.
Unlike the 350Z on which it's based, the V35 Coupe comes with a rear seat and still has a decent sized boot. It is a very comfortable and competent cruiser but can also be unleashed on the weekend at the track or strip.
Only 26,xxx kms on the clock
PRICE: $37,000 or trades with a cash adjustment my way
CONTACT: 0408 155 206 or PM
PICS:
Notes -
The car has received a light car-park scrape on the LR wheel arch (not pictured) this will be repaired prior to sale on receipt of a deposit.
The standard springs are currently fitted (driveway issues) the lowered springs can be refitted or provided with the car.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
