im guessing you mean this?
http://www.carsales.com.au/used-cars/priva...amp;distance=25
you know u can just copy and paste the ad? will get a whole lot more interest on this site anyway~
Edited by tricky_dan
Brief Comments
One of the tidiest R32 GTS-T's around. Cooler...PowerFC....Eboost etc....
comments
Sadly the time has come to depart with my Skyline
as a 4 door is now required.
It is very clean and i regularly get told the same by strangers.
I have owned the car for around 4 years and am the 2nd Australian owner
and was purchased with 60,000 klms on it.
It has been serviced by Bezerkly Automotive in Wollongong
who did most of the Skylines in the area and oil has been changed every 5000
ks.
The car Features.........
3 inch Exhaust.....
Front Mount Intercooler....
Splitfire Panel Filter....
Eboost Boost controller....
APEXi Power FC computer and Hand controller Tuned by "Hitman" Engine management on Standard Turbo on 14 Psi 175 RWKW....
R34 GTT Wheels as seen painted black....
R32 GTR Front 4 piston brake upgrade....
GTR Replica front bar....
GTR Grille and Modified bonnet to suit....
Spoiler removed and holes welded over and repainted by a panel shop....
Exceedy Clutch....
Just Jap Alloy Radiator....
Silicone Hoses....
Just Jap aftermarket coils to fix the Skyline Misfire....
New Leather Gear Boot and handbrake surrounds.....
Car has been through a full EPA inspection and
passes the noise (by 1 DB)
and the emissions test easily.
All the tests are kept in a folder in the car so
if you get hassled by the Po-Po or the EPA whilst out and about you can show them the test results
and avoid the hassle.
Nigel.
Wollongong NSW
$12500 ono
0411022554
Edited by IBOO57
  • 3 weeks later...
  • 4 weeks later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
