im guessing you mean this?
http://www.carsales.com.au/used-cars/priva...amp;distance=25
you know u can just copy and paste the ad? will get a whole lot more interest on this site anyway~
Edited by tricky_dan
Brief Comments
One of the tidiest R32 GTS-T's around. Cooler...PowerFC....Eboost etc....
comments
Sadly the time has come to depart with my Skyline
as a 4 door is now required.
It is very clean and i regularly get told the same by strangers.
I have owned the car for around 4 years and am the 2nd Australian owner
and was purchased with 60,000 klms on it.
It has been serviced by Bezerkly Automotive in Wollongong
who did most of the Skylines in the area and oil has been changed every 5000
ks.
The car Features.........
3 inch Exhaust.....
Front Mount Intercooler....
Splitfire Panel Filter....
Eboost Boost controller....
APEXi Power FC computer and Hand controller Tuned by "Hitman" Engine management on Standard Turbo on 14 Psi 175 RWKW....
R34 GTT Wheels as seen painted black....
R32 GTR Front 4 piston brake upgrade....
GTR Replica front bar....
GTR Grille and Modified bonnet to suit....
Spoiler removed and holes welded over and repainted by a panel shop....
Exceedy Clutch....
Just Jap Alloy Radiator....
Silicone Hoses....
Just Jap aftermarket coils to fix the Skyline Misfire....
New Leather Gear Boot and handbrake surrounds.....
Car has been through a full EPA inspection and
passes the noise (by 1 DB)
and the emissions test easily.
All the tests are kept in a folder in the car so
if you get hassled by the Po-Po or the EPA whilst out and about you can show them the test results
and avoid the hassle.
Nigel.
Wollongong NSW
$12500 ono
0411022554
Edited by IBOO57
  • 3 weeks later...
  • 4 weeks later...
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
