The stock SMIC is a fairly efficient piece of equipment.
Unless you plan to up your boost in the near future, spend your money elsewhere.
Other than that, you can install one for cosmetic effect and if you end up increasing your boost later on, it's there.
but if i install one and keep it stock boost will the car run abit better then having a smic
perfomance-wise told me it would run abit better and that the more air flow the safer ?
I would stick with the stock one mate.
Installing an aftermarket cooler will actually make the engine a little less responsive due to the longer pipework.
thanks its all interesting to hear, because other guys as i said in a previouse post, well they said my car might even gain 1 pound boost and it would run alittle bit better, they said it might lag a tiny but but you wont notice ?
I wouldn't do it. Adds a lot of extra piping on RB25's because their turbo outlet and throttle body are both on the same side so lots of piping wen u add a front mount unless U get a forward facing plenum.
i just like the look of them thats all, so it will not give me any gain wat so ever if im running stock boost ?
No gain what so ever, been stated a few times now.
Just longer piping, potentially less responsive.
ok then so that has cancelled out my plans 99.5 % lol
its just sometimes when my car is boosting on the freeway i dont get much pull and a mechanic said its prob coz your smic is heatsoked ?
You're running a stock car... Of course its not going to have serious pull.
ohh so nothing is wrong ok kool
thanks for that im new to the scene sorry about the ameture questions
when im at a set of lights there is pullback but when on a freeway just a tiny bit and just picks up speed fast, a mechanic told me it wasnt pulling hard because smic was heat soked
but thanks for clearing that up i didnt know !
drop it down to 3rd on the freeway and see if it pulls better. :down:
"IF" it is getting heat soaked you would probably be better off putting some better ducting and a little water mist sprayer in front of the SMIC then going a big front mount on a completely stock car.
yer i dunno coz i was planning on nistuning the car later on so i guess i could get fmic now and worry bout rest later?
Just a thought, but assuming you already have exhaust and air filter upgrades, You would be better off buying an boost controller next, install & up the boost a little bit when you get it tuned. Then when your used to that and you want even more boost, upgrade to a FMIC then retune.
Theres plenty more mods you can do before the SMIC will need upgrading.
i mainly want one coz it makes the car look better looks really good with one on lol
Im glad you said "potentially" ;)
I put a Blitz LM on my R33, running R32 actuator and as far as i can feel it didnt make any difference at all. Marginally shorter piping than your average hybrid piping though. But still longer than SMIC clearly.
My R34 SMIC on my R33 got heatsoaked to the point it would burn my hand if i touched the hot side, and only marginally cooler after a short spirited drive. And it just felt shithouse. So i opted for the front mount. Never looked back.
Yeah no way your SMIC would be getting 'heatsoaked' if you are driving at 100km/h or so already.
Just put're in 3rd gear, RB25DET GB+Diff goes up to 160km/h or so in third and you should feel a bit of pull but I think stock you'll only really feel pushed in the seat in 2nd?
Personally though, as long as at some point you may be putting the boost up or maybe you just want the looks or the fun of modifying the car, I would just do it. Any cons produced by longer piping would probably be neglible and at least it's done which may motivate you to do more to the car.
yer just anotherthing if i dont have any cold air intakes or pod is having a fmic still considered unroadworthy in victoria ?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
