Looking at potentially selling my GT-T.
I'm looking for 25k firm. Please PM me if you're interested.
I'd be keen on a swap, so please PM me your offers (I'd be fine with giving additional cash for something nice).
Modifications are:
Exterior:
Nismo/Altia Bodykit (customised front bar for Intercooler)
Nismo Wing Stay
Nismo Shaded Side Indicators
Nismo Shaded Front Indicators
Nismo Carbon Side Garnish
Custom Pearl Black Paint Job
Volk SF Challenges (17X9 front, 17X10 rear)
Performance:
AVC-R (Black Edition)
Apexi Power FC
Apexi Pod Filter
HKS Split Dump, Trust Front Pipe, HKS Hyper Power Cat Back
Tomei Fuel Pump
Nismo FPR
ARC Front Mount Cooler
HKS Type S Oil Cooler (With Nismo Intake Shroud)
Interior:
Series II (So had interior makeover, much nicer than 99' models)
Nismo Speedo Cluster
Nismo Triple Gauge Center Cluster (Voltage, Oil Temp, Boost)
Nismo Titanium Shift Knob
Recaro SR3 Bucket Seat
Alpine Type R speakers all around
Sony Headunit
Handling:
HKS HyperMax II Coilovers
Cusco Underbody Tension Bar
Cusco Rear Strut Bar
Cusco Front Strut Bar
Cusco Castor Rods
Tuned and Serviced at RE-Customs
Suspension Settings done at ProTek Tyres
Edited by R34_Wong
https://www.sau.com.au/forums/topic/284803-r34-gt-t-2000-manual/
  • Replies 46
Looking to sell more than trade.
At this stage, my main preferance would be for an R34 GT-R with cash your way, but if there are any other offers, please don't be shy to send them my way.
Just found out that it appears there may be an aftermarket HKS Garret turbo within the car. This will be confirmed in 2 weeks at RE-Customs. Price will remain the same if this is the case.
this is one clean mother of a car. and the owner is very very very very very anal about it lol
how anal you may ask? he replaced the center console cause of one small scratch lol
so guys this is one very well looked after car.
gluck with the sale ben. i better get a drive when you get the GTR lol
Hi mate,
She's got 140,000k+. I'll get some interior pictures and post them up soon.
I've got all the papers for servicing and parts installations to go with the car. Also have some boxes for the parts too.
More photos up. Car is going in for a service this Wednesday at RE Customs.
Also, check the ODO and noted she has 130,000+km's on her, not as previously stated.
Also has:
Original Xenon lights
Original Floor Mats
C's Short Shifter
Car has just come back from a service at RE-Customs
Confirmed an aftermarket custom Garrett turbo. :)
Car is going in for a retune and a HICAS lock bar install.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
