hi all time to part out my gtr..
bonet $500.
bonnet with slight damage $350
grill $150
front guards good condition $250 each
front guada with slight damage $150 each
front indicators $80 each
L/H tail light $125
door glass. $150 a side.
rear quater glass $200 each
rear screen oem $350
front screen aftermarket $150
carpet $100
320k nismo dash $350
rear seat good nick not faded $200
doors L/H $350 comlete without glass with trim 400 with glass( early "lightwieght" type-no intrusion bars)
r/h door needs skin $150 as above
window switch $50
front seats abit grubby and drivers one worn abit, $450 pair
atessa pump $200
slightly damaged bootlid $100
bare rear subframe $50
shell will be up shortly. (no numbers) needs r/h quater etc etc...(not rolling)
r32gtr shell with good rear quarters (good for parts/inner panels etc) $1200 (not rolling)
pics up soon
local pickup preferd (toongabbie sydney)
will ship at buyers expence
https://www.sau.com.au/forums/topic/284804-r32-gtr-wrecking/
  • Replies 95
Posted Images
after a price if you got it for the cable that opens the boot/fuel cap and the greyish screw/clips that hold the rear garnish in the boot down. cheers posted to melbourne VIC
why is no one from nsw....
umm shipping would be about $20 for express.
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
