Hey boyz can anyone give me any info on camber toe specs and whether you should run harder setting in the rear?
My car is a r32 gtr has gab adjst coil overs all round i going to run street slicks also going to fit adjustable arms for caster and camber adjustment.
Its makes 573awk on pump fuel so race fuel and no2 should make about 650kw also what tyre pressure you guys run on m/t et drag radials?
Any help would be appreciated thanx in advance
https://www.sau.com.au/forums/topic/284813-gtr-suspension-set-up-for-drags/
auto or manual?
do some testing measuring the contact patch marks on the road....this is how i did it...the result...
1.37 60' with less power than you will have.
basic principles in setting up a 4wd drag car are the same...its the fine tuning that nets the final result...no two cars are the same.
good luck with it.
Edited by DiRTgarage
Thanx Paul
Auto transbrake. so basicly try to get 0 camber when the car leaves the line yea? and 0 toe when its out of the whole
should i stick with the coil overs or go back to standard suspension?'
Thanx heaps Paul
Thanx Paul
Thanx heaps Paul
coilovers allow the car to sit flatter on launch...i gained 60' times going back to coilovers. I had my stockers revalved with 90/10 fronts and 60/40 rears and had trouble keeping the front wheels on the track...so they were shelved. You want about 1mm toe in both sides and positive camber in the rear so you gain contact patch when it launches. Best thing to do is change/test/measure until you see maximum contact patch on the road. Get a nice high ride height with the coilovers and set them with soft bump hard rebound in the rear and the opposite in the front and it should 60 nicely for you. Dom should know what tyre pressures to run with the weight of your car...im not giving all the game away for you...lol
hope this helps...all the best
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
