OK, so it's not a skyline, but it has got skyline wheels and skyline brakes! ;)
In all seriousness, I've joined SAU because I'd love an R32 GTR one day, but since I've already got a toy (this car) and a daily, I simply can't justify another car at the moment.
Here is my baby. It's a red 1977 (RA28) Toyota Celica that I've had since 1999. It was originally very rusty, painted with mission brown house paint (by brush I think!), had a clapped out, single cam, carby, 2L, but did have a 'custom' 80s/90s interior re-trim – wooo!
Stage 1 rebuild (1999-2005) got the body and paint up to scratch, rego'd with the standard suspension and engine.
Stage 2 rebuild (2005) had it fitted with lowered springs and new shocks all round, and a better exhaust.
Stage 3 rebuild (2008) pulled out the old 2L, and fitted a twin-turbo, twin cam, 24V, straight 6 EFI 1G-GTE out of an '89 Toyota Supra. Along with the W58 gearbox, new wiring, new radiator, twin dumps and 3" side-exiting mandrel bent exhaust.
Stage 4 rebuild (2009) is sorting out the suspension and safety for racing. Started with weld on coilover kit/custom hubs/909 discs and skyline calipers on the front, but then started to get serious… specs are below.
I will put pictures and more information up if/when this thread is approved, because I don't know whether Toyota builds are allowed.
Specs @ 24/08/09
OWNER
Timbosaurus
YEAR/MAKE/MODEL
1977 RA28 Toyota Celica
ENGINE HARDWARE
1G-GTE - 2Ltr, 24v, 6cyl, Twin Turbo.
ENGINE ACCESSORIES
Standard Gen3 internals from GA70 halfcut
Front mount justjap intercooler with DIY 2.5" mandrel bend mild steel piping
Unknown lift pump into polished, boot mounted surge tank
Bosch 044 high pressure pump through 8mm aluminium fuel lines
Lift/surge/high pressure setup was ditched for a modified in-tank VE V8 commodore assembly
Beautiful dump pipes from Linden @ roadrunner
Dump merge pipe, through 3" metal convertor and 3" muffler - exiting in front of the drivers side rear tyre.
Whatever K&N filter came with the halfcut
Nicely modified sump from Stradlater
Standard ECU
Gizzmo EBC
Hyundai Excel radiator & twin electric thermo
DRIVELINE HARDWARE
Toyota W58 5 speed gearbox
Unknown clutch that came on the engine
Standard flywheel
Modified RA28 tailshaft to suit hilux diff
Hilux diff, modified with celica mounts
Welded centre, soon to be replaced with a truetrac LSD when time allows
SUSPENSION & STEERING
S13 struts with coilovers and camber tops
Standard front swaybar
No rear swaybar
All front bushes replaced with either nolathane or Superpro
Adjustable panhard rod is needed
BRAKES
Front - 280mm x 28mm nissan discs, R32 GTS skyline calipers
Rear – Stock hilux drums
BODYWORK
Taken back to metal in most places, rust repaired and respray in straight tinter red acrylic.
Alloy rear bolt-in 1/2 cage
Indicators and door locks welded up
ROLLING STOCK
Racing Sparco Python 2
-Front Rims: 17" x 7" JJ Offset 35
-Front Tyres: Falken Ziex ZE-502 215/40/R17
-Rear Rims: 17" x 8" JJ Offset 32
-Rear Tyres: Falken GRB RS Tune 2 235/40/R17
INTERIOR GADGETRY
Re-trim in black and burgandy (came with it when I bought it)
removed centre console for clean tunnel look
Autometer boost gauge
Sparco Monte carlo bucket
STEREO COMPONENTS
none
PLANNED MODS
Get the car engineered
Fit discs to the hilux diff
Fit rebuilt engine with single turbo and programmable ECU.
KE70 corolla front xmember to get R&P steering
Fit rubber donut engine mounts
Fit truetrac centre
If I ever get this far, I might strip it back and do the bodywork properly (i'm picky!)
Let us know what you think/any suggestions.
Timbosaurus
https://www.sau.com.au/forums/topic/284836-timbosauruss-1977-celica/
OH sweet, the thread made it :laugh:
I'll add little sections as I go.
Intercooler piping:
Tacked up...
Welded up...
My welding is not great, so I ground back the welds and gave them a coat of matt black...
The finished product...
Edited by Timbosaurus
Doing the dump pipe merge:
Roadrunner fabrication dumps. Linden is a magic fabricator!!!
I set it up in-car to work out where all the routing for the merge pipes would go. It's pretty damn tight down there with the steering arm getting well in the road.
Once I'd worked out where the merge should sit, I tacked on some rod to hold the position and took it back out to work on the bench. There was no way I was going to be making these pipes from under the car.
Then I sat down with a couple of 180 degree 2 1/4" mandrel bends and my MIG, and got to work.
Time to test fit it.
And it did fit quite nicely indeed...
but the big test was with the steering arms at full left lock.
There's only about 5-10mm clearance there, but that was the best I could do, and I'm happy with that :laugh:
So out it came for welding up. I never claim to be the best welder in the world, and unless welding is perfect there is no point showing it off... so I ground the welds smooth where possible.
And the flanges...
It was getting late by the time I got to the welding up the merge, and I was starting to rush a bit. It hindsight I probably should have left it for tommorow, given that there were some big gaps to fill in between the two pipes. But oh well, it's not a show car ;)
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
