OK, so it's not a skyline, but it has got skyline wheels and skyline brakes! ;)
In all seriousness, I've joined SAU because I'd love an R32 GTR one day, but since I've already got a toy (this car) and a daily, I simply can't justify another car at the moment.
Here is my baby. It's a red 1977 (RA28) Toyota Celica that I've had since 1999. It was originally very rusty, painted with mission brown house paint (by brush I think!), had a clapped out, single cam, carby, 2L, but did have a 'custom' 80s/90s interior re-trim – wooo!
Stage 1 rebuild (1999-2005) got the body and paint up to scratch, rego'd with the standard suspension and engine.
Stage 2 rebuild (2005) had it fitted with lowered springs and new shocks all round, and a better exhaust.
Stage 3 rebuild (2008) pulled out the old 2L, and fitted a twin-turbo, twin cam, 24V, straight 6 EFI 1G-GTE out of an '89 Toyota Supra. Along with the W58 gearbox, new wiring, new radiator, twin dumps and 3" side-exiting mandrel bent exhaust.
Stage 4 rebuild (2009) is sorting out the suspension and safety for racing. Started with weld on coilover kit/custom hubs/909 discs and skyline calipers on the front, but then started to get serious… specs are below.
I will put pictures and more information up if/when this thread is approved, because I don't know whether Toyota builds are allowed.
Specs @ 24/08/09
OWNER
Timbosaurus
YEAR/MAKE/MODEL
1977 RA28 Toyota Celica
ENGINE HARDWARE
1G-GTE - 2Ltr, 24v, 6cyl, Twin Turbo.
ENGINE ACCESSORIES
Standard Gen3 internals from GA70 halfcut
Front mount justjap intercooler with DIY 2.5" mandrel bend mild steel piping
Unknown lift pump into polished, boot mounted surge tank
Bosch 044 high pressure pump through 8mm aluminium fuel lines
Lift/surge/high pressure setup was ditched for a modified in-tank VE V8 commodore assembly
Beautiful dump pipes from Linden @ roadrunner
Dump merge pipe, through 3" metal convertor and 3" muffler - exiting in front of the drivers side rear tyre.
Whatever K&N filter came with the halfcut
Nicely modified sump from Stradlater
Standard ECU
Gizzmo EBC
Hyundai Excel radiator & twin electric thermo
DRIVELINE HARDWARE
Toyota W58 5 speed gearbox
Unknown clutch that came on the engine
Standard flywheel
Modified RA28 tailshaft to suit hilux diff
Hilux diff, modified with celica mounts
Welded centre, soon to be replaced with a truetrac LSD when time allows
SUSPENSION & STEERING
S13 struts with coilovers and camber tops
Standard front swaybar
No rear swaybar
All front bushes replaced with either nolathane or Superpro
Adjustable panhard rod is needed
BRAKES
Front - 280mm x 28mm nissan discs, R32 GTS skyline calipers
Rear – Stock hilux drums
BODYWORK
Taken back to metal in most places, rust repaired and respray in straight tinter red acrylic.
Alloy rear bolt-in 1/2 cage
Indicators and door locks welded up
ROLLING STOCK
Racing Sparco Python 2
-Front Rims: 17" x 7" JJ Offset 35
-Front Tyres: Falken Ziex ZE-502 215/40/R17
-Rear Rims: 17" x 8" JJ Offset 32
-Rear Tyres: Falken GRB RS Tune 2 235/40/R17
INTERIOR GADGETRY
Re-trim in black and burgandy (came with it when I bought it)
removed centre console for clean tunnel look
Autometer boost gauge
Sparco Monte carlo bucket
STEREO COMPONENTS
none
PLANNED MODS
Get the car engineered
Fit discs to the hilux diff
Fit rebuilt engine with single turbo and programmable ECU.
KE70 corolla front xmember to get R&P steering
Fit rubber donut engine mounts
Fit truetrac centre
If I ever get this far, I might strip it back and do the bodywork properly (i'm picky!)
Let us know what you think/any suggestions.
Timbosaurus
https://www.sau.com.au/forums/topic/284836-timbosauruss-1977-celica/
OH sweet, the thread made it :laugh:
I'll add little sections as I go.
Intercooler piping:
Tacked up...
Welded up...
My welding is not great, so I ground back the welds and gave them a coat of matt black...
The finished product...
Edited by Timbosaurus
Doing the dump pipe merge:
Roadrunner fabrication dumps. Linden is a magic fabricator!!!
I set it up in-car to work out where all the routing for the merge pipes would go. It's pretty damn tight down there with the steering arm getting well in the road.
Once I'd worked out where the merge should sit, I tacked on some rod to hold the position and took it back out to work on the bench. There was no way I was going to be making these pipes from under the car.
Then I sat down with a couple of 180 degree 2 1/4" mandrel bends and my MIG, and got to work.
Time to test fit it.
And it did fit quite nicely indeed...
but the big test was with the steering arms at full left lock.
There's only about 5-10mm clearance there, but that was the best I could do, and I'm happy with that :laugh:
So out it came for welding up. I never claim to be the best welder in the world, and unless welding is perfect there is no point showing it off... so I ground the welds smooth where possible.
And the flanges...
It was getting late by the time I got to the welding up the merge, and I was starting to rush a bit. It hindsight I probably should have left it for tommorow, given that there were some big gaps to fill in between the two pipes. But oh well, it's not a show car ;)
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
