Vr4 Mitsubishi Galant Evo Iii
Item: '91 VR4 Mitsubishi Galant Evo III 2.0L turbo
Item Condition: Good
Reason for Selling: I am a student and can't afford a turbo car anymore.
Price and Payment Conditions: Chasing $5500 ono, won't part it out.
Extra Info: Only 200, 000 on the clock with a new timing belt, which is nothing for a '91. Car has undergone a full Evo III turbo conversion including cyclone intake. Has a big td05 turbo, Evo III intake, larger intercooler, large radiator, full 3" inch exhaust from the turbo back, boost gauge, turbo timer, brand new timing belt, new heavy ralliart clutch (5000km ago from Meek), big aftermarket cams (i don't know what brand but they are big). Is sitting on Koni Yellows with King Springs -> It's not a serious combination but combined with the 50/50 awd handles quite well without breaking your spine over every pothole.
I have never owned a car as quick as this. Have a Dyno sheet from previous owner with 178kwatw which was done on a loose timing belt that has since been replaced with a strong and tight aftermarket one. Mechanic reckons she is pulling almost 200kwatw. I never go really hard in her but the few times i have she has ripped pretty much everything at the lights, eats stock STI's for breakfast. Definately the best car you can get performance-wise for the price imho.
Inside is really comfy. No rips in the dash (which seem to be in most vr4's) or the seats. I am 6'4" and i fit fine in both the back and the front
Outside there are a couple of scratches (it's a '91, what do you expect) but no rust that i can see anywhere on the car.
Has been serviced regularly and got the clutch replaced by the guys over at Meek Automotive. Got all receipts and whatever.
Why so cheap? Head gasket is gonna need replacing. Other than that the car is in tip top shape (as far as i am aware).
I wish i could keep her but i am poor (damn the student life).
Pictures:
Contact Details:
Call me on 0410 559 807 or fang me an email at [email protected].
Edited by Rev
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
