S13, 180sx, Gearbox & Conversion Stuff, Calipers, Wheels, Exhaust, Turbo, Engine, Ecu, Manifold
S13, 180sx, Gearbox & conversion stuff, calipers, wheels, exhaust, turbo, engine, ecu, manifold
Front mount intercooler kit with piping and blow off valve $200
s13 rear brake calipers $100
s13 skyline front brake calipers made to fit s13 $150
Tail shaft $100
Gearbox with slave cylinder and line and shifter $600
R32 GTR wheels $500
With tires
r32 wheels sprayed black $100
with tyres
REAR DIFF CV SHAFTS $50
3" Straight through exhaust turbo back $200
Mandrel bent, high flow cat and heat wrap
2x sr20 red top standard turbos $100 each
2x sr20 red top heads "top end" with cams and bits $300 each
2x sr20 bottom ends $300
One seized from fuel in oil
One turns detonated piston 2
MUST GO
2x sr20 exhaust manifolds $80
2x sr20 intake manifolds $80
ECU red top standard $100
ECU red top nistune! $300
Can retune!
Tuned for 300HP fmic, disco spud and greddy easy cams
Will need retune depending on your application
in wollongong nsw
STRICTLY
prices not neg
pickup only
0430748716
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
