i have a bodykit which has been molded to the front guard. Is there any other way?
You shouldn't need to remove the front guard only the guard inner liner (above the wheel) to reveal the loom where it passes through the firewall. You will need to remove the ECU plug, body loom attachment plugs (3 off) and relays one at a time through the firewall and into the guard area. I have found it easier to then pull the rest of the loom (in the engine bay) through the inner guard into the left guard area.
Hope this helps.
