Yeah jesse its one crazy car skipping lanes no problems.
Changed badges did you justin last i seen you had a 13.
Fair ramp Paul pulled f'n hard come up nice on the rollers puts my car to shame.
Needs a 3 bar map sensor and some more boost and will be a crazy wagon
Its a 2 litre motor. The 1.8 is the BPT found in the laser and 323's.
The engine code is FE-DOHC. It comes factory in the Jap, NZ and European 626's. Never came factory turbo though.
David also tuned my 626, but with a mere 230kw its no match for the white one!
This car has a Toyota 4AGZE gearbox in it, with a custom made adaptor plate, you could bolt one of these 2litre motors into your toyota with our plate , you'd only have to make one mount :(
yeh but itll be a lot more work to get the mazda motor to rwd than the toyota motor id reckon
either way i already have the 20v
plus i duno how itll go engineering a 2litre turbo in an originally 1.3 sohc carb :P
dont be a girl nick the mazda 2.oL goes bloddy hard would break the old toyota in half.
you better be bringiing it to me to work on.
Hey West we can do pretyy much anything tell me more on what you need done?
Matty for sure let me know when you want it done now using Martini oil so she will be looked after
lol yeh i know ill get ripped
but i still like the old toyota, plus wanted it to stay toyota on toyota action :thanks:
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
