  • Replies 64
this just appeared above the web page :cool:
Warning: Unknown(../vbp_includes.php): failed to open stream: No such file or directory in /home/skycom/public_html/global.php(929) : eval()'d code on line 2
Warning: (null)(): Failed opening '../vbp_includes.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/skycom/public_html/global.php(929) : eval()'d code on line 2
https://www.sau.com.au/forums/topic/28493-bug-report/#findComment-591415
avatar changing is rooted... only allows you to delete, propbably coz the avatar library is in a different dir now.
Half the emoticons don't work, again I think its the same problem.
https://www.sau.com.au/forums/topic/28493-bug-report/#findComment-592849
I've finally managed to post under another username.
My original username is 'Shane'. I've had to use this username to post this bug.
When the forums came back up, I updated my email address for 'Shane', the forums should have sent out a confirmation email but I didnt get one.
I assume there was no emails sent out at all by the server in past 4 days or so e.g. subscribed threads, newly registered users...
So basically I'm locked out of my 'Shane' account.
The pasword reset is now sending an email but its not doing anything, and says invalid password.
Can my account be reset or something?...
Shane
https://www.sau.com.au/forums/topic/28493-bug-report/#findComment-592872
I just thought I would reiterate (spelling) what funkymonkey said in regard to avatars...
I can't upload or even do anything besides delete my current one which I did by mistake thinking it would take me to an upload/update page for my avatar...
I know the new vBulletin will take sometime to get running perfectly, but as the thread says..."Bug Report"...I haven't noticed anything else, but I never really used it to it's fullest abilities anyway...:-)
Cheers.
https://www.sau.com.au/forums/topic/28493-bug-report/#findComment-593657
Quick insignificant one...
In the user profile screen the following is stated:
If you select your birthday then other forum members will be able to see your birthday on the forum calendar and in your profile. Adding your year of birth is also optional.
If I try to add my year of birth without a month / day, it doesn't seem to stick.
Month / day without year works fine.
Month / day with year works fine.
https://www.sau.com.au/forums/topic/28493-bug-report/#findComment-593688
Hey Guys,
The uploading images thing will be fixed shortly.. simple permissions issue.
Strutto - Its because I have setup the 'age' thing on the left.. if you post the year, it wants to calculate the age, so it needs the others... if you dont post the year, it will ignore the 'age' field entirely.
Christian
https://www.sau.com.au/forums/topic/28493-bug-report/#findComment-593716
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
