Hi Prank
Know you are really busy with all this stuff at the the mo but HELP--
My usual login is blackdoggette - I can login ok and forum recognises I am online but as soon as I try to post, look at my profile or PM someone I can an error back (largish) that looks like I am not activated or something???
I joined about a month ago so am assuming with the recent forum death and re-birth that something is very amiss...
I sent you an email (of course I tried to PM and post but couldn't) very early today and hadn't heard anything so I joined forum again tonight using this username - Nissy
Help
---many many thanks
when it gets all sorted I will let you know and you can delete this account
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-595091
  • Replies 64
Hey just a fiew things, you probably know them all already.
1. in the change avatar option there is only the option to delete.
2. Webmail isn't working? Outlook works fine tho :rofl:
3. FTP to upload to webspace doesn't work? (ERROR: Windows can not access the folder, make sure you typed the file name correctly and have permission to access the folder.) in the pm you sent me you said
*Server; ftp.skylinesaustralia.com
*Location; http://www.skylinesaustralia.com/members/endorean/
thats not my username perhaps its pointing to someone elses webspace?
That is All :D
Thankyou Very Very much :)
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-598140
PranK,
It appears that you can edit other people's gallery images, manipulate them and add text. Obviously there is a very bored/sad soul out there which finds it funny. Don't know what the login area for it is for? Username and P/W don't work there??
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-600010
You would have to be pretty bored. Would be good if the only people who could edit your photos, are you and the moderators. Still wouldn't stop bored souls posting rubbish though and as the gallery grows, it may become a problem keeping track of it all. It will be a damn shame if stronger restrictions then that have to be put in place.
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-600414
FTP should now be working.
Sing out if theres problems.
C:>ftp skylinesaustralia.com
Connected to skylinesaustralia.com.
220 SAU FTP
User (skylinesaustralia.com:(none)): [email protected]
331 Password required for [email protected].
Password:
230 User [email protected] logged in.
ftp> put boot.ini
200 PORT command successful
150 Opening ASCII mode data connection for boot.ini
226 Transfer complete.
ftp: 192 bytes sent in 0.00Seconds 192000.00Kbytes/sec.
ftp> ls
150 Opening ASCII mode data connection for file list
boot.ini
ftp: 10 bytes received in 0.00Seconds 10000.00Kbytes/sec.
ftp>
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-602587
dude all links that don't point to forums.skylinesaustralia.com/forums don't work. I think it used to be either forums.skylinesaustralia.com OR www.skylinesaustralia.com/forums.
Even the notification emails are wrong :D
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-606797
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
