hey guys though ill post up my car build, its not a skyline but it shares a skyline motor :D
the car has been off road for bout 2 years, just simply gave up and left it sitting there, due to a defect notice :D
bur resently i put a hold on my vn ss project and pulled the car cover off the s13, and boy do i miss driving that car, it was my first car, so much love for it
when i first bought it (in 2006) it had a rb20 in it, that motor lasted about a year, then bought a stock series2 r33 half cut and got the motor out of it and droped it in, with in the first week of getting it running again with new motor , i copped a yellow sticker (defect notice) and smashed my diff as well, then depression started kicking in and just didnt want to deal with the car no more. untill now.
all the body work was done by previous owner, which he done a great job with and wont be changing the looks, maybe just a new bonnet, so ive been working on the motor and interior
Engine bay:
Series 2 RB25det
Greddy T67 25g
6boost manifold
Greddy intake manifold
Q45 thottle body
greddy catch can
tial 44mm gate
nismo copper radiator
twin thermos
nismo 740cc injectors
Trust fuel rail
bosch 040 pump
full 3" exhaust, no cat, no muffles, only cannon
alloy over flow bottle
Driveline:
RB25det 5 speed box
nismo lighten flywheel
some heavy duty clutch from the old rb20
custom tailshaft
cusco 2way with 4.3 gears
Suspension:
Tein HR coilovers
Solid subframe bushes
whiteline front and rear swaybars
cusco rear struct brace
5 Stud conversion
s14 brakes
stotted rotor all round
green stuff pads all round
Wheels:
racing hart cps10
18x9 front +21
18x10 rear +27
nexen 225/40 front
nexen 255/35 rear
Interior:
momo steering wheel
3x defi guages
Apexi avcr
Apexi rsm
dash mat :D
s14 seats (will be getting bride seats shortly)
autronic ecu
pioneer double din dvd player
4x 6" pioneer speakers
18 grade tint
trust gear nob
Exterior:
Msports front bar
vertex sides and rear
wise front wide fenders
east bear mirrors
carbon fibre boot by charge speed
clear crystal type indercators/parkers/tail light
think thats it probably forgot some pieces but you get the idea
some parts that are listed arnt on car but do have them waiting to go on
heres a couple pics, the engine bay one, i was just dummy fitting the turbo to see how it will look
will get betterpics soon
cheers chris
https://www.sau.com.au/forums/topic/284962-rb25-powered-s13/
brodie7- Cheers man, was gonna get a sr22det which made 600hp in jap land but the guy wouldnt want to part with it lol, but the rb25 is still good.
matt77- ok im gonna try to make this sound simple, keep in mines these are perth prices and this was about 2 years ago, so will vary if your not from here
R33 manual series 2 half cut- $2800
labour to do conversion-$1500
custom tailshaft-$700
suspension- came with car but go for around $800 second hand for tein's
diff-$650-700 for a second hand 2way
bosch 040 fuel pump $200 ish (new)
you would also need a cefiro crossmember, there probably around $200-$250 (only guessing), dont know what previous owner did to mine to make the rb20 fit
my car made (on stock turbo) 229.7rwhp (sumthing like that) on 10psi, catback exhaust,front mount cooler,pod, stock front/dump pipe with major hole (very bad leak), and had a flat spot from 3500rmp to 4500rmp (round there), but still went hard
abit pricey conversion but worth it, but you gotta remember you have to get your cluster (both km/h and rpm) recalibrated due to the the big gear box, and goin 6cylinder, also would need to run thermo fans too, hope that help, if you want more info let me know
cheers chris
cheers chris
  • 3 months later...
  • 8 months later...
hey dude hows the water temps with the thermos and what not with the 25 in the bay of the s13
im doing the same conversion atm and having mixed opinions about cooling wise using thermos and what not
cheers
andrew
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
