Hi all,
I don't post much on these forums anymore- life just gets too busy! Anyhow, I'm looking to save for a house deposit and sadly this means that the skyline needs to go.
Carsales link with photos:
http://www.carsales.com.au/all-cars/privat...&__Qpb=true
Details:
Picton, South-West Sydney NSW. Around 1 hour from Sydney CBD by car, off the Hume Highway via M5
Price: $11,200
Specifications:
-1996 Nissan Skyline R33 GTS25T 2 door coupe
-5 speed manual
-Wine red colour
-100,000kms
-Climate control
-Electric windows/mirrors
-Tinted windows
-Factory rear strut brace
-Factory 16” alloy wheels
-Nismo shift knob
-Rego to July 2010
-3 point immobilizer, keyless entry
Modifications:
-Xforce cat-back exhaust system (not overly loud)
-Xforce high-flow cat
-Front-mount intercooler
-Apexi pod filter in enclosure
-Greddy Type RS blow-off valve (plumbed back)
-Trust heavy duty timing belt, genuine Nissan water pump (fitted at 88,000kms)
-Walbro 500hp fuel pump
-Whiteline front and rear swaybars
-Project Mu front and rear brake pads
-ADR approved braided brake lines
-Silicone radiator hoses
-New fan and air-conditioner belts
-Front strut brace
-Radiator air deflector
-Turbosmart boost tee mechanical boost controller (set at 9psi)
-Apexi Super Neo piggyback ECU (professionally dyno-tuned)
I have paperwork / receipts relating to all the above.
I am the first owner in Australia, having purchased the car with 77,000kms in stock standard form. Cosmetically it remains stock standard. Car is always warmed up/cooled down before/after driving. I am a mature, non smoker, non-p plate driver and have never driven the car aggressively.
Car is in great condition inside and out. It does however have some minor paint faint/deterioration (mainly boot lid and spoiler), but the car has never been in an accident. It has a Japanese Kenwood CD/Radio that came with the car- this doesn’t pick up Australian radio and doesn’t appear to play cds properly.
Professionally tuned on the dyno to produce 170kw at the wheels at 9psi- a very safe, reliable tune that suits this car as it is my daily driver. Serviced every 5000kms. Modifications are as listed above, and all have been professionally installed and tuned by performance workshops.
Reason for sale- looking to place a deposit on a house.
Contact details:
Ben
As mentioned, I'm not on here much so please contact me via email if you are interested or have any questions.
Thanks,
Ben
https://www.sau.com.au/forums/topic/284983-1996-r33-gts25t-manual/
  • 4 weeks later...
  • 4 weeks later...
  • 4 weeks later...
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
