You could get a 5 stud conversion.
OR, you could go old-school and buy 15-16" rims such as work equip and ssr mk1/2/3, then slam it. But no one on this site is really into that kind of modifications =/
There are plenty of decent 4 stud rims. Depends how bad you want it and how well you can research.
What exactly do you want?
https://www.sau.com.au/forums/topic/285012-why-the-f/#findComment-4787851
You can get a lot of 4stud rims from tempe Tyres. I got my rims from there about 2 months ago
Lenso Type-M
Colour: Black with red lip
Mono block design
They have a lot of designs and they have a website
https://www.sau.com.au/forums/topic/285012-why-the-f/#findComment-4787860
Well i'd like to have an 18" wheel preferably a mesh design.
https://www.sau.com.au/forums/topic/285012-why-the-f/#findComment-4787865
the r34 came out with 5 stud :D;) maybe consider doing a stud conversion? at least you will have more options rim wise then
still na :down:
agreed - get some baller dish man with close to 0 offset :)
party time!
https://www.sau.com.au/forums/topic/285012-why-the-f/#findComment-4795428
just another thought too man, i think i saw 4 to 5 stud spacers on boost or ns
dont know about the legalities and that kinda stuff - might be worth checking out if you are after a cheap option :)
personally id leave it 4 stud and get some doriteks,
but i guess it depends on where you want to go with your car - what style ur going for etc etc
https://www.sau.com.au/forums/topic/285012-why-the-f/#findComment-4795433
you can buy proper 5 stud adaptor type things or kits using Silvia or R32(i think) hubs from Japanese Import Spares in Adelaide, they also stock random rims (they had a set of Ray's Gram Lights in +35 and 4 stud at one point)
I'd be going for a nice set of Enkei's or something myself if I had an inferior model haha
https://www.sau.com.au/forums/topic/285012-why-the-f/#findComment-4798280
    • Probably being in IT for 2 decades, and spending my time documenting trees worth of shit and also being on the receiving end has taught me a thing or two.
    • Why's that depressing, wouldn't it be able to go indefinitely until the battery gets old and craps itself? If it's constantly on charge/maintaining charge, won't that keep the battery healthy?
    • One of my concerns initially was if something catches fire somehow.
    • I think I know what you mean. I saw the same thing a while back, I think either the images on the website were wrong or the model was slightly updated. It was weird when I first looked at it, same model but different looking unit.
    • At work we've got a smaller version of the Projecta that Duncan posted above. At home, I have an ALDI trickle charger. Ive had it for about 8 years now. Only issue with it, it's a smart charger, so if the battery is dead, it won't bring it up, but I have a variable power supply that I limit current on, and set to a max of 14.4v. once it starts charging up, I put the aldi unit on and remove the variable PSU. ALDI one will do 12v, or 6v, then has mode for "car" "motorbike", and "snow". With car or motorbike more for its internal workings, and snow is the trickle mode. I have a battery in the garage that lives on this charger for about the last 18 months now on Snow mode. When I need to charge my other batteries (eg, ones that have died in a car), I get them started and then run it on car mode. Voltage is always sitting really nice, and hasn't killed a battery yet. that charger isn't good for things like Lithium batteries etc, I'd only use it on Lead Acid.
