  • Replies 221
Thanks.
The plan has been to take pic's of each stage as it goes back together. So far I've got pic's of the damaged cast piston (#1), the new CP pistons, completed head, completed bottom end & now these ones. Next will be the complete engine with all ancillaries fitted as it goes in.... well that's the plan anyway.
Hopefully if all goes well it'll be back in the car in ~1wk.
Originally posted by Bl4cK32
Engine looks sexy :D James does nice work.
Yeah I'm really happy with the look of the engine. Can't wait to get it back in the car & running!
Matt (BOOSTD),
Dunno' why #1 seems to be the first to go? From the stock manifold flow bench results you'd think 1 & 6 would be least likely to run lean? It may have something to do with either, a. fuel rail pressure as you go start to get serious with fuel demand, b. temperature due to less cooling airflow, c. stuffed if I know?
AutoTrust,
Thanks. Oh yeah, you can add... nothing like getting flogged by Excels & Lancers off the lights whilst your slowly running the new motor in, to your list too :cool:
Bl4cK32,
I did 95% of it myself. Then James had them finished off by his usual polishing mob, dunno' who that is though? They also did the CAS & fuel rail.
It took me a good few hrs to get the rocker covers & factory cross-over pipe to look 95%! The hard part is getting past the rough casting stage, especially on the pipe! After all my hard work I ended up getting the pipe ceramic coated anyway :D Still a better starting point gives a better end result. I couldn't be stuffed polishing up the plenum so as you can see it was ceramic coated as is. As was the throttle body, IC pipes & custom inlet pipe.
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
