  • Replies 221
Knore,
Do you mean EVERYTHING? As in all internal engine work, bolt-ons (turbo, FMIC etc...) & all lines polishing and so on...??? If so I'd take a few months at a rough guess. Sourcing all the parts, getting the time to do the work & then setting everything up can easily blow out to faaar longer though!
If you mean just the appearance stuff, then ~2-3wks.
All the best with it, which ever way you decide to go mate.
Hip,
Naa not finished yet. Still got a few more little things up my sleeve. The fuel lines & Speedflow fittings are yet to be done (see f/hose on inner LHS guard). The polished turbine heat shield is yet to go on. A few more silicon lines, new stainless clamps etc... Polished radiator air guide. New seats will go in early in the new yr too.
The list is endless...... :)
f*ck your cars clean whatsisname!
ohh you missed a spot on the firewall just behind the turbo :)
Doh! LOL :) Nice pick up! That's an area normally obscured by the dump pipe (off ATM being modified) Thanks for pointing it out, I'll give the area a once over :)
Mattress-The car is looking sweet dude.Are you still going to fit the Ricermatic? :D  :)
           -congrats on the posting aswell.Damn that means i have to put up with Tania for a lot longer! :)  :)
catch up with ya soon
G'day Matty,
Thanks dude :)
Mate I might go with 3 x Ricermatics, should be good for 15-20rwkw each! :)
Yeah we're stoked on the posting/promotion. More $$$, a nice fat lump sum payment, & best of all 3+yrs more in the defect capital of OZ - Adelaide.
You'll have to put up with Tan & me :D Well you see me & put up with Tan :) hahaha
Cheers mate.
Here's the new pic -
No coolant, just water for the run in phase.
It'll go straight on the dyno, but only for a basic check & a bit of load to help with ring bed in.
It'll be a few wks before any serious dyno work takes place.
I've just put 700 kms on mine - It's sweet as ! Has the best exhaust note eva and power - sheeez - Only running 9 PSI and I reckon it has more power than the old motor running 14 PSI.
Yeah - same re Serious Dyno work !
Hope to hear about your results soon whatsisname.
Cheers,
Joel, I have found they tend they start to feel more responsive, rev easier and pull harder, but I have only run in 2 engines, and it could be a case of wishful thinking.
Then again, I rode my brothers new bike (picked it up), then again in a couple of months and it definately felt alot more responsive.
I hadn't actually Hip! :D
Edit - Ok... you busted me Steve :D
Well I picked the car up yesterday (15Dec) & after 80k’s it already feels soooo good to be driving a Skyline again! The down side is having to do 2000k's of painfully tame running in mileage :)
The engine starts & runs as if it were still stock on the inside (nice & smooth - nil piston slap). It actually feels "more" responsive than I recall, possibly helped by a dump pipe change & lighter reciprocating mass. It also still has plenty of RB25DET off-boost torque, something I’ll be using a lot in the next few 1000k’s.
I might see a few of you in the hills in the coming wks, I’ll be the one driving very sedately: )
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
