  • Replies 221
Knore,
Do you mean EVERYTHING? As in all internal engine work, bolt-ons (turbo, FMIC etc...) & all lines polishing and so on...??? If so I'd take a few months at a rough guess. Sourcing all the parts, getting the time to do the work & then setting everything up can easily blow out to faaar longer though!
If you mean just the appearance stuff, then ~2-3wks.
All the best with it, which ever way you decide to go mate.
Hip,
Naa not finished yet. Still got a few more little things up my sleeve. The fuel lines & Speedflow fittings are yet to be done (see f/hose on inner LHS guard). The polished turbine heat shield is yet to go on. A few more silicon lines, new stainless clamps etc... Polished radiator air guide. New seats will go in early in the new yr too.
The list is endless...... :)
f*ck your cars clean whatsisname!
ohh you missed a spot on the firewall just behind the turbo :)
Doh! LOL :) Nice pick up! That's an area normally obscured by the dump pipe (off ATM being modified) Thanks for pointing it out, I'll give the area a once over :)
Mattress-The car is looking sweet dude.Are you still going to fit the Ricermatic? :D  :)
           -congrats on the posting aswell.Damn that means i have to put up with Tania for a lot longer! :)  :)
catch up with ya soon
G'day Matty,
Thanks dude :)
Mate I might go with 3 x Ricermatics, should be good for 15-20rwkw each! :)
Yeah we're stoked on the posting/promotion. More $$$, a nice fat lump sum payment, & best of all 3+yrs more in the defect capital of OZ - Adelaide.
You'll have to put up with Tan & me :D Well you see me & put up with Tan :) hahaha
Cheers mate.
Here's the new pic -
No coolant, just water for the run in phase.
It'll go straight on the dyno, but only for a basic check & a bit of load to help with ring bed in.
It'll be a few wks before any serious dyno work takes place.
I've just put 700 kms on mine - It's sweet as ! Has the best exhaust note eva and power - sheeez - Only running 9 PSI and I reckon it has more power than the old motor running 14 PSI.
Yeah - same re Serious Dyno work !
Hope to hear about your results soon whatsisname.
Cheers,
Joel, I have found they tend they start to feel more responsive, rev easier and pull harder, but I have only run in 2 engines, and it could be a case of wishful thinking.
Then again, I rode my brothers new bike (picked it up), then again in a couple of months and it definately felt alot more responsive.
I hadn't actually Hip! :D
Edit - Ok... you busted me Steve :D
Well I picked the car up yesterday (15Dec) & after 80k’s it already feels soooo good to be driving a Skyline again! The down side is having to do 2000k's of painfully tame running in mileage :)
The engine starts & runs as if it were still stock on the inside (nice & smooth - nil piston slap). It actually feels "more" responsive than I recall, possibly helped by a dump pipe change & lighter reciprocating mass. It also still has plenty of RB25DET off-boost torque, something I’ll be using a lot in the next few 1000k’s.
I might see a few of you in the hills in the coming wks, I’ll be the one driving very sedately: )
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
