Nah, bit different one or two (or even a few) going for a spin through the hills, dont see many cops - but every cruise I have been on, well they seem to notice alot of nice cars, and on public hols, I get scared:D
I had to push it hard, I was trying to keep up with a slammed, every sus mod, very lightened S14. Started loosing front end grip first, so I slowed a bit more for the corners - then the S14 started getting away - then comes a corner that I didnt see until it was too late:p:D If only you could get a skyline to handle like a sylvia, the ultimate car. Anyways, I still have a few things I can do to tighten things up a bit, enough excuses.
  • Replies 221
Dont mind having a bit of a play, but not really into street racing, thats where problems start. Maybe next track day, if you dare:D
At the moment, I reckon a bog stock V6 commodore would get me off the mark, just cant get any traction through 1st or 2nd - 3rd is where the fun begins for me (gotta get some decent rubber dammit)
They are tweaked. I have also done front and rear strut braces - the turn in is great, just the tyres dont grip too well when you go fast enough:D I woudnt mind a bit more camber in the front, but that means adj camber arms. I would love to drop the car about another inch, but the front bar wont like it at all - protests now. and some nice R rated rubber.
matt... you're still doing powerslides?? man you are crazy ... reminds me of the time u took me for a ride in your car ... farkin freaked me out u bastard ... i thought u were going to loose it LOL but nope u had it all under control ... (well i just thought u were lucky at the time :D) ... anyways be careful ... i'd cry if that car had even a scratch on it!!! :D
Steve: I dont mean racing, comon, wer more mature than that, i mean, next time we are up for a cruise, we should stick together, just like wat u wer doin with the s14 :D
Sly33: Greenline in japan sellin them for about 9,800 yen, + about max 2500 shipping. I calculated that to about $150 using current exchange rate. I get my parts from them and so have many others.
http://www.greenline.jp/catalogue/bcpartli...=R33B&intake=FI
The tuning has been done :)
The old engine made a best of 257rwkw on .95bar, this figure was achieved with a less than 'safe' tune. I say less than safe as it cracked a ring land.
The new engine (with a nice 'safe' tune) made 268rwkw on 1.1bar & 273rwkw on 1.3bar. The peak gain between 1.1 & 1.3 doesn't sound like much but the torque & mid range gains are impressive (700n of tractive effort & ~20rwkw). The minimal peak gain is due to boost dropping by ~2psi up the top end. A 1.0bar actuator, or increased tension with the current actuator, would see a few more rwkw on the same boost levels. I wasn't exactly suprised that the actuator problem arose.
Judging by the increase in power & torque (across the rev range) that 2psi made, & the fact that inlet temps don't increase with the extra 2psi, I'd say my turbo still has more in it. I'm sure that with 1.5-1.7bar it would make quite a bit more power. I'm very happy with ~270rwkw on 1.1bar all day everyday :)
A huge thanks to Shaun (Boost Worx) for spending the best part of 2days on final tidy- up work & tuning, & charging me stuff all considering the number of hrs!
Good stuff Matt, when are you heading out to the strip?
There is a easy 12 for the taking I reckon with that sort of power - see if you can knock of Grepin and Freebaggins time and set something for them to chase!
Turn it up!
Great stuff Matt, you'd be very happy with that! Very timely re 4,6 & Rotor shootout.
Your turbo is smaller than mine so that power at that boost is excellent, interesting to see what timing Shaun was able use safely.
When are we gettin some other scrubbers on the track!?!
Plenty of cars with good power that can get into the mid 12s now.
Thanks guys :)
Timing is 15' on 17-19psi.
The cars next run @ AIR will be during the 4,6 & Rotary Nat's :D Shaun gave me an offer I couldn't refuse :)
Late breaking news! As the car is still at the workshop (had a few minor things to do) Shaun is going to run more boost/timing to see how much it can make for drag strip duties :mad: Gotta' love the Microtech LT handsets ability to hold 4 different maps :)
I'll probably stick with 540's mate, HPI style :D
Another small piece of info that's worth mentioning.... the original plan was to use 8.0:1 CP pistons & o'ring, however this plan changed to using a Grex 1.6m gasket. Due to this change I thought that the final CR had ended up @ 8.4:1, however the final ratio is indeed 8.0.
We can now lean on the timing a tad more than we have :mad:
cool, or see if you can get some Nitto's from somewhere? 540S are still great, as Greg showed, just need a good 2nd gear Burnout to get some heat into them - don't wear them out too much, as you know they have been replaced with the RE55S, which are stickier than 540S, so would be better for drags I reckon - just didn't last long enough for me to find out!
I'll see how I go on the everyday 540's. I'm not expecting too much, I haven't dragged the car for a looong time! Yeah I doubt I'd go for 55's after your experience with them, unless they've improved them?
Here's the dyno sheet from the recent tuning. The power dropping off at the top end of the curve is due to the 2psi boost drop I mentioned above. And for those that are real nit pickers, yes I know the 17psi run is only 265rwkw but the best on 17psi was 268.Xrwkw, so there :D
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
