Thanks guys. The credit goes to quite a few different people, including a number on this very forum :P
knore,
The latest Microtech LT series ECU is ~$1300-1400 (rough guess here) & the LT series handset (can do programming, basic logging, real time data & 4 maps) is ~$160 I paid $145 a yr ago. The LT ECU can be tuned via laptop & is the prefered method as it allows more tuning options.
The mid range power is fantastic on the road, but it does require a bit of sensible throttle control.
  • Replies 221
Someone from Adelaide has a handset in the For Sale section ATM for $100 (used) and they are from Adelaide.
Happy spending :P
The one for sale is the MT 4 line handset (holds 2 maps). Mine is the 2 line LT (holds 4 maps)
The 4 line HS scrolls real data time across the screen, whereas the 2 line has a stationary display of selected real time data.
so why the microtech over pfc ?
We won't get into that argument, it gets ugly as people become very sensative to whatever ECU they have bought (I have Microtech and it works well). Better to do your own research ALL ECUs and make up your own mind.
There seems to eb this myth that the PFC is the be all and end all for R33s. They are just like most other programmable ECUs, with ALL having dissadvantages and advantes over each other.
Matt, great numbers and I also agree re Microtech, I asked Shaun to do a Valet map a while ago but in all honesty I could have done it myself, they are so easy to do and then save onto the next spare Memcal. I know because I accidentally overwrote Shaun's Valet map and had to do it again myself :Oops:
Excellent stuff Lach ! Thanks for that. Looks like we could both do with an upgraded actuator, yes? I have an Apexi one lined up (get it tomorrow) I'm hoping it's 1.0bar rated. If that doesn't fix the drop in boost then I guess the housing &/or wastegate is the problem?
It's amazing how close each of our power curves are given the big differences in set-up!
Hurry up & do the Tomei cams so I can see if I should do them too :worship:
EDIT: Oh yeah, what's the go with using PINK for my p/curve? What are ya' trying to suggest :cheers:
Knore,
I couldn't agree more with Lachlan, it really comes down to what ECU suits YOUR needs. I chose Microtech for a number of reasons. Cost, features & local support to name just a few.
Gotta alot things on my plate at present so have stalled the cam upgrade. Woudl be nice to have a look at a better exh manifold with it, so $$ start adding up.
I have 400R bar to go on next week and that is more $$ so motor stuff will wait a while.
So yeah, not sure if top end torque power drop off on mine and yours is stock exh manifold (Grepin has nice manifold), EDIT actuator spring (Grepin has HKS actuator), int wastegate design (Grepin's HKS int gate exh housing is also very nice)......good to see you're trying one. I mention Grepin's stuff due to the strong power curve right up top.
So fit and tune with Apexi actuator tomorrow?
Yeah understand re lots on plate, & $$$ adding up.
400R bar will look excellent & slightly better airflow into FMIC.
I figure that the actuator is the easiest thing to check, & the Apexi one is free so why not give it a shot. I won't know what boost its rated at till we test it though. Getting the actuator tomorrow then organise with Shaun to fit/trial. Tomorrow arvo maybe?
It may well be manifold/housing restrictions. Grepin's results seem to support this theory. Then again he has an HKS actuator! See how we go I guess.
Excellent curve plot there Freebaggin. It clearly illustrates that a rwkw figure isnt the be all end all number on which car is the fastest. IMO, the fastest car will be whatsisname's (providing he shifts ~1000rpm than the other 2 cars), even tho Greepin's car has a higher rwkw figure. Either way, all 3 cars have very nice power!
Dammit, i want a RB25DET now!!!
Here's Steve's lastest dyno run
*Note* - he has since made further changes & gained MORE power!
Noice numbers....
Matt, what turbo are you using again ? I've forgotten :)
Cheers,
Bl4ck32,
Very nice mate :) How long till the motor is ready to go?
B-man,
How much longer till we see your beast making 300++rwkw? It'd have to be ready for tuning soon wouldn't it?
My turbo is a bit of a bitsa. Garrett bush bearing T3/T4 .60 comp .64 ex. It has a big comp wheel shoved into the .60 housing & the ex wheel has been back cut. Those in the know have had a look & estimate ~450-500hp potential? Still using stock, port matched HPC coated, manifold.
Cool - nice one.
Mine had a bit of a set back - The turbo couldn't puff more than 255 rwkw - (it was a T04e comp, VG30 Exh hybrid...
Anyway yeah - HKS 3040 going on now with all associated manifolds and wastegates -
Should be ready early next week as we neeeded to get some fabrication done, flanges built, new dump pipe, etc.
Stay tuned ! :)
Some big numbers being made by the SAU SA R33 contingent, great stuff!!
We should try to get in on a private test day at AIR again, so everyone can have a few runs and get some quick timeslips to go with the dyno charts :D and do it without the pressure of a open street meet
The last one was great, and I can't wait until we get a day like that agian
There will be a couple sleeper 300rwkw R32's 'idling' around adelaide soon also.. :D
Problem is I need a stock RB flywheel so Andrew can balance up the RB30.. Think I can find one.. No sir..
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
