Nah, bit different one or two (or even a few) going for a spin through the hills, dont see many cops - but every cruise I have been on, well they seem to notice alot of nice cars, and on public hols, I get scared:D
I had to push it hard, I was trying to keep up with a slammed, every sus mod, very lightened S14. Started loosing front end grip first, so I slowed a bit more for the corners - then the S14 started getting away - then comes a corner that I didnt see until it was too late:p:D If only you could get a skyline to handle like a sylvia, the ultimate car. Anyways, I still have a few things I can do to tighten things up a bit, enough excuses.
  • Replies 221
Dont mind having a bit of a play, but not really into street racing, thats where problems start. Maybe next track day, if you dare:D
At the moment, I reckon a bog stock V6 commodore would get me off the mark, just cant get any traction through 1st or 2nd - 3rd is where the fun begins for me (gotta get some decent rubber dammit)
They are tweaked. I have also done front and rear strut braces - the turn in is great, just the tyres dont grip too well when you go fast enough:D I woudnt mind a bit more camber in the front, but that means adj camber arms. I would love to drop the car about another inch, but the front bar wont like it at all - protests now. and some nice R rated rubber.
matt... you're still doing powerslides?? man you are crazy ... reminds me of the time u took me for a ride in your car ... farkin freaked me out u bastard ... i thought u were going to loose it LOL but nope u had it all under control ... (well i just thought u were lucky at the time :D) ... anyways be careful ... i'd cry if that car had even a scratch on it!!! :D
Steve: I dont mean racing, comon, wer more mature than that, i mean, next time we are up for a cruise, we should stick together, just like wat u wer doin with the s14 :D
Sly33: Greenline in japan sellin them for about 9,800 yen, + about max 2500 shipping. I calculated that to about $150 using current exchange rate. I get my parts from them and so have many others.
http://www.greenline.jp/catalogue/bcpartli...=R33B&intake=FI
The tuning has been done :)
The old engine made a best of 257rwkw on .95bar, this figure was achieved with a less than 'safe' tune. I say less than safe as it cracked a ring land.
The new engine (with a nice 'safe' tune) made 268rwkw on 1.1bar & 273rwkw on 1.3bar. The peak gain between 1.1 & 1.3 doesn't sound like much but the torque & mid range gains are impressive (700n of tractive effort & ~20rwkw). The minimal peak gain is due to boost dropping by ~2psi up the top end. A 1.0bar actuator, or increased tension with the current actuator, would see a few more rwkw on the same boost levels. I wasn't exactly suprised that the actuator problem arose.
Judging by the increase in power & torque (across the rev range) that 2psi made, & the fact that inlet temps don't increase with the extra 2psi, I'd say my turbo still has more in it. I'm sure that with 1.5-1.7bar it would make quite a bit more power. I'm very happy with ~270rwkw on 1.1bar all day everyday :)
A huge thanks to Shaun (Boost Worx) for spending the best part of 2days on final tidy- up work & tuning, & charging me stuff all considering the number of hrs!
Good stuff Matt, when are you heading out to the strip?
There is a easy 12 for the taking I reckon with that sort of power - see if you can knock of Grepin and Freebaggins time and set something for them to chase!
Turn it up!
Great stuff Matt, you'd be very happy with that! Very timely re 4,6 & Rotor shootout.
Your turbo is smaller than mine so that power at that boost is excellent, interesting to see what timing Shaun was able use safely.
When are we gettin some other scrubbers on the track!?!
Plenty of cars with good power that can get into the mid 12s now.
Thanks guys :)
Timing is 15' on 17-19psi.
The cars next run @ AIR will be during the 4,6 & Rotary Nat's :D Shaun gave me an offer I couldn't refuse :)
Late breaking news! As the car is still at the workshop (had a few minor things to do) Shaun is going to run more boost/timing to see how much it can make for drag strip duties :mad: Gotta' love the Microtech LT handsets ability to hold 4 different maps :)
I'll probably stick with 540's mate, HPI style :D
Another small piece of info that's worth mentioning.... the original plan was to use 8.0:1 CP pistons & o'ring, however this plan changed to using a Grex 1.6m gasket. Due to this change I thought that the final CR had ended up @ 8.4:1, however the final ratio is indeed 8.0.
We can now lean on the timing a tad more than we have :mad:
cool, or see if you can get some Nitto's from somewhere? 540S are still great, as Greg showed, just need a good 2nd gear Burnout to get some heat into them - don't wear them out too much, as you know they have been replaced with the RE55S, which are stickier than 540S, so would be better for drags I reckon - just didn't last long enough for me to find out!
I'll see how I go on the everyday 540's. I'm not expecting too much, I haven't dragged the car for a looong time! Yeah I doubt I'd go for 55's after your experience with them, unless they've improved them?
Here's the dyno sheet from the recent tuning. The power dropping off at the top end of the curve is due to the 2psi boost drop I mentioned above. And for those that are real nit pickers, yes I know the 17psi run is only 265rwkw but the best on 17psi was 268.Xrwkw, so there :D
    • Thanks for all that information I appreciate it. To answer your questions: - Yep that's what I mean. These guys are professional painters to so I must be missing something. It's a bit hard to explain. - With the primer landing on clearcoat, I make sure that the surrounding clearcoat is scuffed to 240 grit as my epoxy primer says that I only need to sand the area to 240 grit. - Yeah so similar to the first question, assuming that the paint landed on the unscuffed clearcoat because I've seen that happen. - Yep I want to prep the surface in that order. Only reason because epoxy primer will protect it from rust and I need that atm with this crappy Sydney weather. I think I was worried about time, if I try to put the filler down but screw it up somehow and I don't have time to sand it off and reapply it then need to put primer later that it might start to rust again so I wanted to apply the primer as quick as possible to not deal with rust.  - My car has heaps of small dents, that definitely need filler but are you also sanding the area to 240 grit to fill it in with filler? I always thought you have to go to bare metal for filler to stick but that contradicts the point then that you can put filler on epoxy primer.  If you aren't going to bare metal, AND not putting epoxy primer how are you making the dent stick to the paint?
    • I did. I went to a suspension guy and he told me because I don't have adjustable camber arms it's the reason why my car veers towards the left if I take my hands off the wheel but if I drive my other every day car and take my hands off the steering wheel it goes completely straight. I think it's common with Skyline's. In order to fix the problem, I likely need gktech camber arms then nismo bushes since I have poly bushes atm, then a wheel alignment after that. With my car if I take my hands off the steering wheel on a really bumpy road before stopping at a light I have to hold my steering wheel somewhat tight otherwise my car will legit just go completely in the other direction quite quickly and I'll slam into something lol instead of stopping straight. I Believe this YouTuber had the same issue and fixed it with gktech arms. At timestmap 6:05 he talks about how the car doesn't veer anymore after installing these arms.
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
    • I don't know the answer to this, but did you have a look at the parts diagrams on amayama.com and see what they list around it for your car? As an example this should be it on my car. That's how I would check for required clips and things like that. But, I take no responsibility for you ending up with a box full of random OEM hoses, washers and clips after going down that path a few times. This definitely has never happened to me
    • Most driving should* be done on one side of single lane divided roads. In the RHD world, you drive on the left side of the dividing line and the road is probably cambered equally on both sides. So your side of the road slopes away to the left. The same is true for the LHD world, just everything swapped to the other side and opposite slope. With a perfectly neutral, straight ahead wheel alignment designed to drive straight on a perfectly flat surface (or at least one that is level on the left-right axis, even if it has some slope in the fore-aft axis) you will not be able to drive on a cambered road without the car wanting to drift down the camber. You will need to add steering input in the opposite direction all the time. This is annoying. The solution has always been to set the camber and/or the caster to produce a continuous turning force in the opposite direction of the camber. The car will drive straight on the kind of camber for which it was set up, presumably as described in the top paragraph. But.... when the car is set up this way, as soon as you get into a lane, usually on a multi-lane surface road or highway, where the camber is not as presumed during setup, the car will usually pull to one side. In the RHD world, if you are in the fast lane on a big divided road, you are probably on the opposite camber compared to what the car was set up for (ie, sloping down to the right) and the combination of the setup and that camber will make the car want to go right pretty hard. Even a perfectly flat lane will tend to want to go right. There's no getting around it. Civil engineers who know their stuff (which is not an assumption that can always be made) will attempt to keep the variation in camber across a multi-lane road as small as possible, and if they can will attempt to make the fast lane as close to flat, or even cambered in the same direction as all the other lanes. This takes a lot of planning for drainage, control of levels, ability to deal with the elevation changes that occur at road junctions, etc etc. So it's not trivial to get it right. When they do make it work, then the annoyance is reduced, along with tyre wear, fuel consumption, etc. In theory, the civil engineers are supposed to worry about those aspects of road design also. * This used to be true, but now with very large highway systems, even just multi-lane surface roads running everywhere, it is less true now than it was, but the old assumption is the basis for describing the phenomenon, so let's just run with it for the moment.
