Having put braided lines on my N14SSS (which already had a brake upgrade with AD22VF calipers/rotors from the GTiR, along with DBA slotted & cross-drilled rotors) - i was suitably impressed with how much 'bitier' the brake pedal was and in general the brake feel when I had custom ADR-approved lines made up - I was very impressed. I knew when I bought my R34 GT-T that braided lines I would definitely be on the list of modifications.
I ended up ordering my ADR approved braided brake lines from a brake supplier in Melbourne that was mentioned on SAU (can't remember their name - was it Brake West?). They have this weird metal device in the middle that my brake guy said wouldn't be able to replicated if he'd sent them off to get made into braided lines (which I'd done for the N14).
However, after having them fitted, I wasn't as impressed with the braking improvement / pedal feel on the R34 in comparison to the N14; not as noticeable, but still there.. not sure if I could recommend it.
yeah is only that one block that the guy at my brake place can't get. he has spoken to his supplier and he said that the only way to get it is to send one overseas and get it made and order a min 20,000 items. so i don't see him doing that in a hurry.
Just go to www.maltech.com.au They make complete front and rear replacments for stageas. ADR approved with the ADR numbers stamped on the rubber boots at the end of each fitting on each line (so there won't be any issues if you get inspected). I got a set off them front and rear for my series one. They fitted perfectly and bolted up exactly as the standard ones did. They also do custom ones, so if your fitting R33 calipers and need the fittings changed they should be able to handle it. Very friendly and made them up and posted them to me very quickly. You can also choose the colour of the braid and the rubber boots too if thats your thing. My old lines were ok but were starting to show signs of wear. I fitted the lines front and rear, dba and dixcel slotted rotors front and rear and dixcel sports pads with motul racing brake fluid. Once they were bedded in the change was amazing (still using standard calipers). I'd already had a descent set of pads on my stock setup but still had little pedal feel and a bit spongy feel when braking hard. Now I have a very firm pedal feel which makes for much more confident braking. Once you get some heat in them (even though cold performace is good) they bite very hard for some time before they start to fade still yet to fit a MC brace. From memory the price was quite good on the lines too.
Here are some pics from when I did it last year. Their not great but you get the idea. Easy job to do.
Afternoon,
Has anyone with a 260RS S1 fitted braided brake lines to there car?
Just curious as I've seen a seller on ebay selling adr compliant ones for R33 GTR, one thing the add mentions was that different version of R33 have different lengths which made me wonder whether I should just get one's for a C34 Stagea with R33 brembo connectors.
me thinks they are completly different, as the stagea lines come from one side and go over the hub then down to the caliper. i haven't seen a r33 gtr but the lines that i have seen for them don't look remotely the same.. and if you were to fit them they wouldn't pass main roads as they don't follow the factory design.
Curt
Just letting everyone know that we can provide ADR approved lines at a very competitive price, email us for details ([email protected]) and if we have 5+ people we can give you all a nice discount too. :D
Curt
I didn't see this in time, I ended up buying them last night. I'll reply to this thread to let everyone know if they were the same in case there are others out there looking at doing this. I wanted them to add to my existing group buy for RDA slotted and dimpled rotors with ebc pads. Worst case i might be selling some ADR compliant R33 GTR braided lines and will get the existing one's measured to make custom ones.
Got my braided brake lines fitted to the car today, well atleast the front anyway.
For anyone else with 97 260RS, the R33 GTR braided brake line kits aren't a complete match. The fronts fitted without issues though the rears have a completely different connector. I've sent a message to the supplier giving them stock Stagea model types to see if they have done these before.
i got a quote back from maltech for $520 del for a 8 hose set.. i'm waiting on an email back telling if that means like 2 full sets or what. if there are any guys on there that want a set we could get a group buy going to get it alitle cheaper too.
I bought a set of hoses from Maltech for an RS4 but the front hoses were a little short - they worked but couldn't be secured the same way as the old ones. If anyone has an old set to send them they could make their Stagea set a better match. (Have a local source now myself).
For the record, I sent Maltech my front & rear standard (Brembo) brakelines off my 1998 S1 260RS about 2 years ago now as at that time 260RS was a bit rare or so it seemed. As I understand it Maltech already had the standard Nissan line patterns for RS4 series Stageas by then. So they should have the correct patterns/lengths for both RS4 & 260RS.
Maybe give them a call & I would be telling them about your front hoses being a bit short at the same time.
Regards GW
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
