As stated in title, wrecking a 1997 R33 SII Skyline.
The vehicle is black in colour and was a manual.
Most of the interior parts are still available. All panels and headlights on the front of the vehicle has been sold.
PM for any parts required.
Prefer pickup on heavy parts, but don't mind posting smaller trims.
Thanks!
Edited by DRFT33
https://www.sau.com.au/forums/topic/285065-wrecking-1997-r33-sii/
hey mate just wondering if you still have the diff? if so does it have a 2 or 4 bolt rear hat that bolts it to the cradle? if it is 2 bolt which i think it will be would you be keen on selling/swapping just the rear cover, cheers. im in adelaide aswell by the way
Thanks!
Thanks!
disco potatoe - Sorry not seperating any engine parts but depends on what you're after? I have GT3582R turbo, X-Force high mount manifold, Tial 38mm wastegate, 3inch dump and screamer, braided oil and coolant lines for $2200. 80mm throttle body - $150. Let me know what you're after exactly.
pingping - I do have the ashtray. I can send you picture but it just looks like all the other ashtrays? Anyway - $20
Muges180 - As above, if pingping doesn't claim it, then the ashtray is yours for $20. Center console lid - $20
Zoidberg - Front and rear seats available. $150 for the lot. RHF seat has minor stitching come off about 1cm.
lolnic - $150 for all the seats if Zoidberg doesn't want them.
dor180 - Sorry, the locks have been sold.
2FST4U.R33 - handbrake tip available. The grip looks worn though? let me know how much you want to pay for it.
Turk1 - Sorry, front grille is gone.
Craig132 - Front brake calipers and rotors - $250. Rear brakes may have been sold but I will let you know.
codys97 - I'm not sure on the rear diff, I'll need to have a look but it is the VLSD (GTR rear diff) model so might be completely different from what you're after.
Darren33 - Not sure on what you're after buddy.
Bigmikespec, Aberax, Weezy, F9292 - trying to send PMs at the moment - will get one soon.
Hi there, i'm desperately looking for The R33GTS-T Crossmember, RB25DET Rubber Mounts & RB25DET Allumunium Engine Mountings, if you still have it i will take it. Please let me know ASAP. My email: [email protected]
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
