Hi guys
I'm quite new to this forum and have recently become a member of SAU NSW club. I've tried searching with some success, PM'd people on the forum who've helped me out quite a bit and have even spoken to people outside but still no practical solution.
OK case is ... Just recently I've got my hands on a R33 gtst series 1 but not a normal one, the whole body except doors, roof and rear fenders are carbon, RB26DETT swap thats been rebuilt plus aftermarket turbos, Full roll cage through the whole thing, pretty much a race car. The car is currently road registered in QLD but now because i've got it down here in NSW, i'll have to do the whole rego thing again. Now this is where it starts to get complicated.
GOAL: To be able to drive the car to the track or workshop and back home without getting in trouble with the authorities.
I've sussed out a couple of options:
1. Taken a look at Rally registration - This seemed to be the perfect idea until i spoke to Graham Humphries who is the person who pretty much puts through all the cars through the rally rego system. Because people have been abusing the system, things have changed since the past. So after much talk with Graham, the way its going to work now is that they don't like rally rego'd cars to be used as a system for general motorsport and used only in Rally. And with rally theres pretty much only dirt or tarmac. I aint doing dirt but with tarmac they're mostly interstate which again i ain't doing. So conclusion: NO GO
2. Get the whole car engineered, blue slipped then rego'd - I've been recommended by many to go to Autosport Engineering, so i've spoken to Greg regarding my case and what i'd like to do. Greg's a top bloke, was happy to answer any question i gave him and this seemed like the go until.... we found out that the engineer was notified by the rta that under no condition is he allowed to give an engineers report to any cars of this nature. Apparently there having a crackdown on road rego race cars. So conclusion: NO GO
3. There was an idea to revert the car back to stock to get it blue slipped as a standard car and then put everything back on. I thought that this would prove difficult as everything is pretty much modified so it would take alot of time and labor to get everything back to stock and back on. Besides even if after all that effort and the cars back on the road i'd probably get harrassed by authorities because i have no engineering papers. So conclusion: NO GO
4. Towing the car to and from the track using a trailor - I dont have the finances to afford a trailor plus no car that is capable of towing it. So again its a simple NO GO
This is proving to be such a headache, please guys if you have any ideas please fire away. Thanks for your time
Cheers,
Kevin
https://www.sau.com.au/forums/topic/285081-dilemma/
lol yeh pics would be nice, but i really dont think you can get a full cage and the carbon body parts engineered in and way shape or form apart from a dodgy one in nsw, the engine transplant you could get engineered, cover the pod, no atmo bov or atmo catch can, if using external pumps and external surge tank then that needs a fully enclosed box that drains to outside of the vehicle.
If you do only intend on using it as a race car and not driving it on the road, rather than going through all the hassle and might I add extra cost of mucking around with it to get it to an engineering level then paying for all the engineering, blue slip rego etc, just find yourself a car trailer for a good price and then go buy a 90's model v6 auto dunny door with a tow ball, would do the job. You could fit a change of tires and a heap of junk in the back if you bought a wagon.
also can I ask how much you paid for the r33? oh yeh and pics :)
https://www.sau.com.au/forums/topic/285081-dilemma/#findComment-4788862
Ahh... but man... i don't have the finances and storage place for another car plus a trailor
Hmm then your best bet would to get it engineered and regoed. I guess it will be tough but maybe just strip it back so it can be engineered, then get it regoed. This way your car will be a part of NSW lol and you can continue on from there.
https://www.sau.com.au/forums/topic/285081-dilemma/#findComment-4789171
its not the fact that i badly want it on the road, its just i wanted to get it to the track and back home with the least amount of effort and troubles. And i thought by registering it legally that would be best.
hehe i thought of that as well but apparently we can get carbon parts engineered here in nsw
https://www.sau.com.au/forums/topic/285081-dilemma/#findComment-4792588
  • 3 weeks later...
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
