Hey guys this is my toy, only mild mods at moment. hoping to get a bit more done too it in the next year or so, want hopefully close to 300 rwkw
out of my 20!! if no success ill do a different engine conversion. eg ls1 or 2jz :)
Engine
RB20DET conversion
JJR FMIC,
3inch Apexi Cat back
NGK plugs
Dr. Drift custom tune
Gates sport timing belt and tensioner
Driveline
5 Speed manual conversion
Extreme extra heavy duty solid button clutch
R33 GTST Shimmed LSD
Wheels/Brakes
S15 Front Suspension Conversion
Lovells Sport Springs
KYB Struts
Hicas Lockout Bar
5 stud Conversion
R32 GTR Front brakes
R33 Rear brakes
Volk GTP Rims (17x9.5 +33, 17 x 8)
Rays gold wheel nuts and valve caps
Bendix Brake pads
Other mods
Bosch 044 fuel system
52 mm aluminium radiator
Thermo fans
Cold air intake
Recaro Drivers seat
Momo gear knob
Speco Boost gauge
Double din dvd player/ screen
Alpine Type R front splits
Alpine Type R rear Splits
Clarion 4 way Amplifier
Battery in boot
https://www.sau.com.au/forums/topic/285085-my-ceffy/
  • 1 year later...
  • 11 months later...
Yeah 32 centre console, need to get hold of a ceffy one. I reckon if Benny seen it now he would cry, bit knocked around from sitting in the shed for a year or so. It's back on the road again now running the same 20, very very boring now. Any ideas of cheap mods to get it going a bit quicker? Currently not working so on a budget for now :/
Was thinking 34 highflowed turbo on 17psi?? Thoughts?
https://www.sau.com.au/forums/topic/285085-my-ceffy/#findComment-6046517
send your std turbo in to hypergear ... or buy a china td06 (which is what i'm about to do) , or buy my gt2530 off me so i can buy said td06 :whistling: . the trick to making rb20s' (imo) is keeping things like cooler and pipework as short and small as possible (i.e smallish cooler , pipework as short as possible , i've been looking into smaller radiators and running upside down coolers/one sided coolers to shorten piping up , the only issue i'm getting is keeping the std inlet mani (seems to work best for rb20)
can you even get defected in tassie?
high mount and screamer pipe :nyaanyaa:
Well you can , if you drive silly enough pinch.gif , apparently popo is coming down on 'illegal' mods and we're gunna be line ball with other states , then i'll move to perth :P
Edited by toffy
https://www.sau.com.au/forums/topic/285085-my-ceffy/#findComment-6050778
