My question is will i actually get an r34 gt-t cheaper if i import it my self? Ie would i be able to get a decent stock r34 for like 15k? I am going to japan at the end of the year does being there in person help this proces? Wheres the best place to start looking? Do i start looking at a place like tradecarview.com, then get in contact with a importer? Im not hunting for an amazing car just wanna save money is there any point considering the low AUD buying power? Help is appreciated cheers
https://www.sau.com.au/forums/topic/285113-will-i-actuall-save-money/
its probably not worth the hassle as there are so many here already for sale under $20k with a few mods.
The best bit being you can actually drive and inspect them. I always thought i would import but by the time i go the coin together i realised there were heaps of cars available in Aus with no 3month wait.
pretigemotorsport.com.au
J-spec.com.au
ironchefimports.coms
Are good sites to get an idea
my personal thing is cars worth under $20K on the road are not worth importing. and no you being in japan wont make things any easier or better. unless you have access to dealer auctions and can speak and read japanese and know how the auctions work... if you want to import just pick your exporter, broker/whatever and get them working on it. but seriously a stock R34 GTT is not worth that much these days, you are better off hassling sellers for a deal here.
thanks guys, thats the picture i was getting from import ad prices. i am going with a japanese friend but sounds like it would be cheaper here. cheers
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
