Hey guys, i've got a JBL self-powered speaker up for sale, It's absolutely brilliant for house parties etc, it's in great condition, used a couple of times this year, and it's always been tuned to the proper level when it is on, i do look after them, trust me on this. reason for selling it beacause i just got an upgrade.
They are $1250 brand new!! ex-hired are $850 from DJwarehouse
Selling for $500 ($580 with Stands)
Comes with set of XLR, and power cable
More info:
http://www.djwarehouse.com.au/cat/index.cg...oduct_id=689259
Pickup in Hills area
Pm or buzz me 0411887820
https://www.sau.com.au/forums/topic/285114-jbl-self-powered-speaker/
Here are the SPECs:
About JBL EON15 P 15" Active PA Speaker
Perfect for Live sound reinforcement, speech, vocals, and music playback in entertainment, A/V, and institutional venues – especially when ease of use, audio quality and portability are important factors. Also suitable for amplification and monitoring for electronic musical instruments.
Specifications
* 15" LF driver with neodymium magnet
* 1.75" HF compression driver
* 130 watts LF amp power & 50 watts HF amp power
* 21kg net weight
* Rated Maximum SPL: 127 dB, @ 1 m (3.3 ft)
* Dimensions (H x W x D): 686 mm x 430 mm x 444 mm (27 in x 17 in x 17.5 in)
* Ferro-fluid cooled.
* Input Sensitivity: -55 dBu to -2 dBu for rated output (Mic/Line switch in MIC position)
* +9 dBu to +26 dBu for rated output (Mic/Line switch in LINE position)
* Enclosure Material: Aluminum baffle, gray co-polymer enclosure and protective bezel
* Audio Connectors:
* Input XLR/F, balanced
* LoopOut XLR/M, balanced
* Crossover Freq.: 1.5 kHz.
* AC Input: Switchable 115 - 230 VAC (±10%), 50 - 60 Hz., 175 watts rating per UL, detachable IEC (male) power connector.
$400 ono!
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
