I need to change the oil in my diff (its limited slip) so i went to nissan to see what they recommended. i was told to use Mobil LS90 synthetic lsd oil. is this correct?
i went to autobarn and they don't stock it but the guy there looked up a catalogue and he said for all nissan diffs you can use non-lsd oil in limited slip diffs. he was convinced i should get non-lsd oil. i then ran out of the shop :) it didn't sound right to me!
so what do you guys reckon? i ended up getting castrol lsd oil from bursons (who said the guy at autobarn was an idiot).
so is the guy at autobarn really an idiot or is it ok to use non-lsd oil in a lsd?
thanks
Greg
logic would say its not reccomended. if theres a lsd oil and u got ur hands on it already then theres no need to ask this question.:):D is there a big price diff bewteen the two..better to spend that extra for piece of mind than to listen to someone who needs to look in a book to answer u question.
If you have a viscous LSD centre then you can use an 'ordinary' diff oil. OTOH, LSD diff oil should be used if you have a mechanical LSD (clutch centre, etc).
If you not sure, use an LSD oil...the difference in price is hardly worth worrying about and certainly won't do any harm.
yeah it is a viscous LSD, so i guess autobarn 'idiot' was right, well half right. he didn't know that i had a viscous LSD.
i looked in a mates owners manual tonight and it reccomends hypoid gear oil 85w-90 - which is non-lsd oil so yeah. but if its not going to wreck anything then i'll just put in the lsd oil, as you said B1, it can't hurt.
thanks for the replies guys :D
went back today and got castrol VMX80 80w90 gear oil because i thought i should do what owners manual says. also got a pump. changed it myself, easy job - takes 1.3 litres. it feels heaps smoother around corners, i'm heaps more confident to enter corners at speed now :P
  • 4 weeks later...
before you go to autobarn, know what you want, get it, and get out before one of the staff tries to give you 'advice'...... most of em dont know shit.
-rb25
haha so true especially around this time of year all the teenages are working and most of em know things in theory that they read in magazines etc thats about it!
Is changing Diff oil a difficult process i have never looked into it do you need special tools or anything??
Whats involved ??
I think it's about time i do mine cause evernow and then it does single spin.
Maybe i should just fork out the cash for a mech lsd
oh wells any info appreciated.
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
    • And, given that you're in NC, go buy an LS7 or something equally sweet and piss that crappy old RB off. Or call up Wesley Kagan and get his help putting a Merc V12 into it.
    • Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
