  • Replies 40
you'd do well in that pozzy Steve...........seriously
would also be a good chance to get you 2 buggers working together rather than against each other.
On that note, I also nominate Steve (MADAZ) :)
Ruby you have a PM
RubyRS4 here ... problems with my regular account. :)
Luke, I'll reply once my post count is up past 10. For some reason my login has errors when I try to PM, reply or post in a thread. Not sure whats wrong with my account. I just need to whore it up a bit, so I can quickly send Pete and Shane a copy of our conversations and my comment for Pete and Shane to ponder over.
Haha. Should of kept my mouth shut. Although it would be nice to give something back to SAU, im not very good at planning anything.
I'll try and organise some cruises and track days later on and see how they go.
you would make a good one with the first event organised you quickly learn how you can do the next one better
wow sorry Pete kept you bust today didn't i :) to have so many quotes in the one reply
advice from other thread taken on board but not entirely agreed with but that's not for here
I nominate Luke ENR34, he is a two fisted drinker so he must be organized ...lol
or Madaz secondary
Can we create a new position for SAU TOKEN DRUNK .... and for that i would nominate Luke ENR as he has showed and proven to us his drunk skills....
Agree with james on the 3 choices posted up Luke, Martin and Luke all good choices
I am an agent of chaos.
I hereby nominate Madaz.
-D
was i ment to get a pm?
Yes. I'm aware I contacted two Lukes :P
no but i would like to formally nominate Luke ENR for the position.
Damo you twit, it was your idea for Luke ENR so I PMed him :);)
PM sent Madaz
I'm sure you have the same Qs Luke has, so I have copied my reply to some questions to you also.
Think it over. :)
crap forgot about martin , I nominate him as a canadate as well
Is that a Canadian thing? :P
Shane, Pete and myself are currently discussing the nominations/suggestions. Work in progress. We should have some news for you all shortly.
:P
:P
Not sure Canadians talk funny..lol
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
