if you seriously did ALL the suspension bushes we are talking thousands of dollars in parts and labour. there are heps in the rear end (diff mounts front and rear, UCA, LCA etc).
  • Replies 42
Posted Images
yeah start with the basic ones like castor rod bushes, front upper control arm bushes, if you have GTR then front lower control arm doesn't have bushes, do the steering rack mount bushes, and swaybar mount and link bushes. then move on to the rear, rear upper control arm, rear lower control arm, rear traction rod, then the 4 big subframe bushes and do the diff cradle mount bushes and the diff mount bushes and the rear swaybar bushes too. that's most of the key ones. car will feel like new after that. it adds up pretty quick, just getting all the diff bushes is something like $400 or more, subframe bushes for the 4 proper replacement ones is about $180, and then there's the labour of removing every arm and the rear subframe and diff. if you can do a lot of the work like removing the bits yourself and just take the arms and subframe somewhere to get the bushes done that will save a lot of $. subframe ones are still tricky as they are basically burnt/cut/pressed out and can be a bitch to do. most of the others are just press out, press in.
yeah best just to do it piece by piece as time and funds permit. also doing it that way you'll get to see which ones really do affect handling/nvh/feel etc. and which ones you cannot even tell you changed!
To give you an idea i'm spending around 6 - 7k including suspension , and that's pretty much all bushes including new wheel bearings, rebuilding drive shafts ect..
The rear ones are hell expensive by the way.
Oh and all the cleaning and painting was done by me to help bring the cost down
Some pics
well apparently all the rear in mine are stuffed, and some in the front. I'm getting the cradle bushes first, and the others as I can afford them I guess, not really going for anything adjustable though (not sure just how much of the suspension components are common to GTS-4 and GT-R either), seems like it would almost be cheaper to get a whole new rear subframe etc!
GTS-4 and GTR stuff is all the same, ( someone please correct me if i'm wrong )
Ok i was quoted $1000 from Nissan for a new subframe ( through my mate who works at Nissan which he get's trade price and then a further 10% discount )
So i hate to think how much it would really cost.
The labour alone in the subframe is about $1000.
AFAIK in the R32 GT-R has diff bushes and GTS-4 dosen't? they do use the same springs/shocks though.
I was thinking a used subframe in good condition lol, labour isn't really a factor for me as much, but either way its gonna be a prick of a job - nearly to the point where I was thinking about selling rather than fixing, but with the current market for Skylines as it is I don't really think thats a viable option.
Can someone please confirm "AFAIK in the R32 GT-R has diff bushes and GTS-4 dosen't?"
If Labour is not really a factor then it would be better just to replace the sub frame bushes.
Or you can go the pineapples which will not cost anywhere near as much to do, however i can not say how long they last.
The thing is if you go the route and pull out your subframe and replace the 4x floor mount bushes and any others that NEED replacing you may as well ditch the four wheel steer as well.
Yeah HICAS is already locked out, and I think it's an R32 thing to not have diff bushes, there was another similar thread not long ago about that... I've got alloy cradle/subframe bushes on the way, thank god, since the car is driving like a VN at the moment!
I'm weighing up my options still - since I'm poor and can't really afford to replace all the individual components, I'm trying to get away with just doing what really needs to be done right now.
yeah I've done every single bush and joint on my 32 (except the 2 front LCA ball joints) and its like chalk and cheese compared to when it started.
so if you want that brand new tight handling feeling, I think it is worth it. I'd rather spend 5k on bushes than turbos thats for sure.
If you mean in terms of removing the subframe i can not give you any tips as to where to start as i didn't do mine
The guys who are doing the suspension work are pulling it all apart,
As they pulled out the Arms ect.. ect.. I go pass and get them, sand / clean and paint them and bring them back.
All i used was 400 sand paper to sand/clean them back
Paint used engine enamel gloss , few coats over each part
To clean the parts before painting i used prepsol
Pain in the ass really , but then again removing the whole lot at home on stands would be a killer.
I'm just too lazy too do that
you would start by taking tail shaft off, wheels, rear brake disks to be to undo the hand brake cable
and after that start undoing all bolts thats holding the subframe to the chassis its pretty straight foward
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
