if you seriously did ALL the suspension bushes we are talking thousands of dollars in parts and labour. there are heps in the rear end (diff mounts front and rear, UCA, LCA etc).
  • Replies 42
Posted Images
yeah start with the basic ones like castor rod bushes, front upper control arm bushes, if you have GTR then front lower control arm doesn't have bushes, do the steering rack mount bushes, and swaybar mount and link bushes. then move on to the rear, rear upper control arm, rear lower control arm, rear traction rod, then the 4 big subframe bushes and do the diff cradle mount bushes and the diff mount bushes and the rear swaybar bushes too. that's most of the key ones. car will feel like new after that. it adds up pretty quick, just getting all the diff bushes is something like $400 or more, subframe bushes for the 4 proper replacement ones is about $180, and then there's the labour of removing every arm and the rear subframe and diff. if you can do a lot of the work like removing the bits yourself and just take the arms and subframe somewhere to get the bushes done that will save a lot of $. subframe ones are still tricky as they are basically burnt/cut/pressed out and can be a bitch to do. most of the others are just press out, press in.
yeah best just to do it piece by piece as time and funds permit. also doing it that way you'll get to see which ones really do affect handling/nvh/feel etc. and which ones you cannot even tell you changed!
To give you an idea i'm spending around 6 - 7k including suspension , and that's pretty much all bushes including new wheel bearings, rebuilding drive shafts ect..
The rear ones are hell expensive by the way.
Oh and all the cleaning and painting was done by me to help bring the cost down
Some pics
well apparently all the rear in mine are stuffed, and some in the front. I'm getting the cradle bushes first, and the others as I can afford them I guess, not really going for anything adjustable though (not sure just how much of the suspension components are common to GTS-4 and GT-R either), seems like it would almost be cheaper to get a whole new rear subframe etc!
GTS-4 and GTR stuff is all the same, ( someone please correct me if i'm wrong )
Ok i was quoted $1000 from Nissan for a new subframe ( through my mate who works at Nissan which he get's trade price and then a further 10% discount )
So i hate to think how much it would really cost.
The labour alone in the subframe is about $1000.
AFAIK in the R32 GT-R has diff bushes and GTS-4 dosen't? they do use the same springs/shocks though.
I was thinking a used subframe in good condition lol, labour isn't really a factor for me as much, but either way its gonna be a prick of a job - nearly to the point where I was thinking about selling rather than fixing, but with the current market for Skylines as it is I don't really think thats a viable option.
Can someone please confirm "AFAIK in the R32 GT-R has diff bushes and GTS-4 dosen't?"
If Labour is not really a factor then it would be better just to replace the sub frame bushes.
Or you can go the pineapples which will not cost anywhere near as much to do, however i can not say how long they last.
The thing is if you go the route and pull out your subframe and replace the 4x floor mount bushes and any others that NEED replacing you may as well ditch the four wheel steer as well.
Yeah HICAS is already locked out, and I think it's an R32 thing to not have diff bushes, there was another similar thread not long ago about that... I've got alloy cradle/subframe bushes on the way, thank god, since the car is driving like a VN at the moment!
I'm weighing up my options still - since I'm poor and can't really afford to replace all the individual components, I'm trying to get away with just doing what really needs to be done right now.
yeah I've done every single bush and joint on my 32 (except the 2 front LCA ball joints) and its like chalk and cheese compared to when it started.
so if you want that brand new tight handling feeling, I think it is worth it. I'd rather spend 5k on bushes than turbos thats for sure.
If you mean in terms of removing the subframe i can not give you any tips as to where to start as i didn't do mine
The guys who are doing the suspension work are pulling it all apart,
As they pulled out the Arms ect.. ect.. I go pass and get them, sand / clean and paint them and bring them back.
All i used was 400 sand paper to sand/clean them back
Paint used engine enamel gloss , few coats over each part
To clean the parts before painting i used prepsol
Pain in the ass really , but then again removing the whole lot at home on stands would be a killer.
I'm just too lazy too do that
you would start by taking tail shaft off, wheels, rear brake disks to be to undo the hand brake cable
and after that start undoing all bolts thats holding the subframe to the chassis its pretty straight foward
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
