For turbine wheels update We can change that to GT2860 steel wheels with turbine housing re-profile and wastegate porting for $700 per turbo.
are these the same as the -5 turbos?
Idential specification. In sleeve bearing.
Just to avoid confusion for others, putting ideal spec wheels in the stock housings won't make it the same as -5 turbos because the -5 turbos use a 0.6 compressor housing and 0.64 turbine housing.
So even more lag
So even more lag
I'm still not 100% sure what stock A/R turbine housings are on the stock turbos but most ppl say they're .48 or something. The stock compressor housings are .42. The 707160-9 wheels would prob work better in the factory machined housings.
A friend of mine did this a few years ago. He claims it has less lag than a set of -7s, but that was several years ago, so I can't really give you any more details than that. A turbo shop in Townsville (John Patrick) did the job for him.
Well. as soon as steel wheels are in. noticeably more lag. Drove N1 and Normal R32, defiantly be able to tell which one's what. Bigger turbine housing will help making more power with more lag, its only a 1.3L 3cyc engine per turbo. I think machine -5 to stock housing would be a less laggy option for up to 350rwkws (I've seen 345rwkws).
So even more lag
So put correctly sized -9's on there for 330-340rwkw if that is what you want.
Just had a look at the stockies
.42 front and .48 rear
does this mean it wont flow as much as a -5s (.64 a/r) after hi-flowing?
No where NEAR what "true" ball bearing -5s will make.
You are basically putting a turbo designed to be in a certain way, into a set of restrictive housings.
You run into potential issues like:
will not make power easily, require fair amounts of boost for the power, create lots of backpressure and potentially higher intake temps for the equivalent power level.
Cutting short by going a sleeve bearing rebuild in restrictive housings
vs
Ball bearing turbo, correctly designed housing/wheel combo
It's a GTR - if your too cheap to afford turbo's to do it justice, begs the question IMO.
With the brand new price of Genuine Garretts these days, rebuilding stock GTR turbos IMO is a thing of the past
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
