Hi all
I have this in my boot and what to know what it is.
After getting aftermarket chip in my ECU, when I turn the ignition on and this relay in the boot started clicking off it's head. I have changed relay and still same issue.
No ECU in and igintion on, no clickity clickity.
Its doing my head in please can some help or offer any assistance.
https://www.sau.com.au/forums/topic/285251-please-help-relay-issue/
Thats what is clicking under my dash (cant hear that from outside). Started doing that when right wiper arm came off on speed. Removing wiper fuze (from wrong fusebox layout) doesnt kill wipers, but kills pretty much all electric parts in the car(Dash, Speedo, Tacho, Windows, lights too i belive etc.) And it stops clicking. What it might be ? And yes its really loud and annoing. Air con lights do switch but it doesnt work actually, it just blows "everywhere" (Legs+front+windscreen)
I believe its the fuel sender relay ?
yeah, gets its power from the other fuel relay next to the ECU. It is also fused, 10 amp, in the fuse box under the dash.
Id check and make sure you have good ground and power at the pins. If you have something loose it will keep tripping the relay on and off.
good luck.
  • 3 weeks later...
