Hey,
What do people think about this: http://www.gtrmod.com/COBB-Tuning-Coilover...ob%209c1800.htm
I want to keep the factory adjustable shock absorbers but also lower it just a little. Looks like these would do?
Anybody got opinions on these? They seem to be a reasonable price.
https://www.sau.com.au/forums/topic/285266-lowering-the-gtr/
Hey,
I used the Mines Eibach Springs in mine and have got a firmer ride and lower ride height. This maintains the factory adjustability. Which ever way you go it is a pig of a job to do as you have to remove the majority of the rear interior to fit whatever you put in.
Good Luck
Good Luck
jpgtr, interesting stuff..what is even more interesting is that you not only own that MAGNIFICENT black GT-R but a 996 911 Turbo as well??- yee hah!
These for me are about the 2 best sports/supercars one can own...how do they compare with one another in terms of performance, drivability, reliability and desirability???
Hey,
Just so you are aware there are a couple of other options of basically the same thing as those Cobb kits. The main thing to determine is what your plans for the car are as they each come with significantly different spring rates.
The Cobb system is pretty much focused on a street set up where as the below 2 systems are a bit more track focused as far as spring rates go.
GTC Racing - http://www.gtc-r.com/
Type 1R - http://www.typeoneracing.com/catalog/produ...=151&page=1
I have a set of the T1R coilover kit (the GTC kit pictured is EXACTLY the same as the T1R kit). Used for 2 days before i switched over to a full coilover kit. I will need to check freight cost but it will end up costing you much less than if you buy a new set direct from Canada (or the UK). PM if you are interested.
  • 8 months later...
Hey,
Just wondering why you went for full coilovers after just 2 days?
and how did the factory adjustable shock perform?
Edited by druzilla32
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
