pulled into coles/safeway carpark today and was confronted by the sheriff
i was in my girlfreinds car which aparently had $1650 in unpaid citylink fines
the thing is there was a glitch in the system and the fines were never received in the mail
they wanted to tow the car on the spot, and she never even knew of the fines.
it is all from 7 trips on citylink over a 2 month span
just a warning... they are checking all rego's in the carpark
i know this may sound like a silly question but in particular with citylink fines (excluding speeding tickets etc), is this directed at the owner or the rego. So assuming if you sold the car will it still show in the system the upaid fines if they type up the rego of your new car?
When you say "glitch in the system" did the sheriff advise you of this or is this your assumption.
Sorry for the interrogation cause a person from my work "apparently" has $18,000 worth of citylink fines. A bit hard to believe but she did come to work in tears.
eastlink is f*ked, i got a fine 12 months after for $300 odd, for using it 9am the sunday it became tolled, the car was on the eastlink register aswel,
if there wasnt monkey operating it, they coulda just charged the account that has the rego link, $2 instead of $300 a year later!!
Coles Carpark behind Chapel was a major hoon hotspot about 4-5 years ago then it got clean after a major crackdown. Was there a few weeks ago and saw that its started to flare up abit but no where near the kaos of previous years.
From what I could tell mostly 16 - 19 year olds that weren't around (and didnt have a license) for the major crackdown that happened there a few years back.
that why they put the concrete barriers in?
i was there about 3-4months i think. They only car spot i knew that would be available, was bout midnight. And the place was half full of imports and other various done-up cars, some people just cruising around the car park, lots of people just hanging around... i was thinking jeebus, it's a coles car park guys, get a life. Just parked as far away as possible, but would have only left the car for say 20mins (dropping friends off)
at least pick a carpark that does have 11ty million concrete barriers
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
